Old 01-20-2020, 03:34 PM
Mcronk Mcronk is offline
Default 68 GTO VIN plate verification
Need help ASAP. Look at picture of VIN plate and let me know if you think it has been swapped from another car. Looking to purchase this convertible. Car has PHS and a copy of current title and they have matching VINs. Just trying to make sure Vin tag has not been swapped. It is a Baltimore built car. I can barely make out the VIN number on the tag only because I know what title says.
Thanks.
Old 01-20-2020, 03:52 PM
Default 68 GTO VIN plate verificationGTO need help ASAP
Looking to buy this convertible. PHS VIN matches title VIN but can barely make out VIN numbers on tag. I want to make sure the tag was not swapped from another car. Thanks
Old 01-20-2020, 04:10 PM
Joe's Garage Joe's Garage is offline
Default Looks like a 1968 GTO convertible to me
24267 8 is clearer than the rest.
Then it looks like B and maybe 109199
But that just means the tag was originally on a 1968 GTO convertible, not necessarily THIS 1968 GTO convertible.
Anything could have happened in 52 years.
Good luck!
Old 01-20-2020, 04:25 PM
This helps at least verify the car is represented as born. Picture of data plate verifies body style, color, convertible top color, interior color and the plate appears original to the car. Still wish VIN tag was "cleaner".
Old 01-20-2020, 05:05 PM
Entropy11's Avatar
Entropy11 Entropy11 is online now
I’d say it’s fine. Just looks like somebody painted over it several times, same as the fender tag.
Hers a similar shot of mine if it helps to compare
Old 01-20-2020, 05:45 PM
Verdoro 68's Avatar
Hard to say for sure without seeing the rivets. Seems odd they’d cake the paint on in this area, but I’ve seen other restored cars that look like this. Does the rest of the car give you any suspicions that the VIN might have been swapped? What about verifying the vin on the frame or the engine?
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
Old 01-20-2020, 06:06 PM
Thanks for the replies. Car matches PHS and billing history card perfectly. It is 875 miles away and I hope to speak to the actual owner today. It is not a extremely rare high dollar car so likelihood of someone swapping VIN tag for profit is unlikely. Also I can tell they laid paint on very thick in areas they worked on.
Old 01-20-2020, 07:13 PM
Good luck!
You did very good on that VIN number! You were only off by the last digit. It is an 8 not a 9. Your eyes are better than mine.
All options on PHS match the car. Data plate appears as original and trim codes match the car as well as what PHS says trim codes should be. Unusual options are all present and help verify VIN is correct for this car. Who would order HO engine then order HD dual stage air cleaner which would replace the free flowing HO air cleaner? The dash was repainted which may account for paint thickness. I was concerned with what appeared to be sealant or glue around edges of dash opening on VIN tag. However the fact the data plate appears original and matches PHS helps me believe the VIN tag is original to the car.
Old 01-20-2020, 07:25 PM
dataway's Avatar
dataway dataway is offline
I wasn't aware there was a difference between the air cleaner on an HO engine and the standard GTO 4bbl air cleaner. The dual stage air cleaner consisted of a thin foam wrap around the air filter element ... I don't think there was any difference in the air cleaner housing.
Far as I know, other than RA engines, the GTO air cleaner housings were all the same in 68. The dual snorkels started in 69. 68 should have a single short snorkel with a pronounced oval opening.
Old 01-20-2020, 09:40 PM
OG68 OG68 is offline
IIRC the two barrel engines had a smaller diameter snorkel but the HO and Std engines did share the same air cleaner.
2007 Cadillac SRX
Old 01-20-2020, 10:23 PM
My bad. I have a 67 GTO HO car that has the open element air cleaner and the 69 GTO'S I had were the dual snorkel air cleaners. My 68 Tempest Custom has a single snorkel air cleaner but is a 2bbl.. I assumed the 68 had the same HO air cleaner as 67. Thanks for setting me straight.
It also helps confirm VIN tag as car has all and only the options the VIN supports with the PHS. Since it is not a rare RA car and the chances of someone going to the trouble to make the car match perfectly seems unlikely I believe the VIN tag is original to the car. Also title says actual mileage was 30,000 in 2012 and current mileage is 38,700. So if someone was going to commit crimes of swapping VIN and tampering with mileage for pretty much a "plain GTO convertible" it seems like a huge risk for little to no reward.
Old 01-21-2020, 01:08 AM
PurelyGTO68 PurelyGTO68 is offline
I believe all 1968 GTO 4bbl engines had the same air cleaner housing....even the RA cars. The RA open pan, hood baffle, foam and open scoops shipped separately and had to be installed at the destination.
Old 01-21-2020, 02:34 AM
So....where are the rosette rivets?
Funny, I can see them on my car but apparently, since on one else asked, you can't see them on any of yours?
Old 01-21-2020, 10:25 AM
I thought the same thing at first. Then I did a search for images of 68 GTO VIN tags and none of them had rivets I could see. Some were from very original cars. Not sure why but maybe it was an assembly plant thing?
What does appear original to car and correct rivets is the trim plate on the cowl. It coincides with the PHS information that is tied to the VIN number. So if you were going to,switch VIN tag you would also have to switch trim plate so everything matched. Then install all the correct options on the PHS exactly as the factory did. Also car is low mileage. Title states actual mileage in 2012 as 37,000. Current mileage is 38,277. VIN tag is hard to read and ugly but other things match up very well to the VIN number on the tag. If this were a RA convertible I would be very careful but it is pretty much a regular 68 convertible. Not a high dollar car.
ID:	529359   Click image for larger version
ID:	529360   Click image for larger version
ID:	529361   Click image for larger version
ID:	529362   Click image for larger version
Old 01-21-2020, 12:22 PM
Gastiresandoil's Avatar
I don't know if they are all the same excluding the RA air cleaner. I think there is a difference as some air cleaner housings have a baffle between the snorkel inlet and the air cleaner element and others do not. Not sure if this is why the screen printed label on the air cleaners have a PP and other have a PB as well.
Old 01-21-2020, 02:23 PM
John Milner's Avatar
John Milner John Milner is online now
Isn’t the rosette portion of the rivet visible from the bottom on a 68?
Old 01-21-2020, 04:15 PM
dataway's Avatar
The rivets are to the rear of the vin tag opening .... I think most are covered up by the padded dash, some are not, some are half covered. My guess is the most in-exact part of the bunch would be the padded dash so that's probably where the differences come from.
Old 01-21-2020, 04:34 PM
I was thinking that the rivet was installed from the bottom of the dash frame, with the bottom of the rivet visible from the top of the dash frame. The rosette portion is visible looking up from the bottom of the dash in my car. I do think that the padded part of the dash covers the rivets up.
Old 01-21-2020, 08:40 PM
gto66yellow gto66yellow is offline
I have seen them both ways . Probably what was easiest for the person doing it.
Old 01-21-2020, 09:59 PM
67428HO 67428HO is offline
Mine are visible looking up at the bottom as well.
67428HO
Thread Tools
Display Modes
