Napa 43102 water pump
ANybody having luck with the napa pump 43102? Im gettin ready to put one on the wagon... i checked fin to plate clearance, its about .100...i should go ahead and massage the plate a little to get a bit closer, right? thanks!
1968 Firebird 10.817/122.33 3600lbs trw 455, iron d-port heads/SD intake/q-jet, 9" tires 1.440 60ft 1962 Catalina 4100lbs trw 455, iron d-ports,perf RPM, 800holley, 9'' tires,(12.157@108.91)1.578 60' Oct 2010!! |
I bought one of them after reading some posts indicating they had a cast impeller, but when I received it I compared it to an original and found that while it does have a cast impeller, it is machined differently that the stock impeller causing a gap similar to what you describe.
I am toying with the idea of pulling an impeller off an original pump I have, and installing on the new pump. This will only work is the shaft sizes are the same, but I've read some posts where others have done it with success.
Michael Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done... |
i thought about that, too...but, wonder if its really necessary......im just gonna massage the cover a bit... get it closer and see what happens.., ive got a stamped impellor on there,now...its gotta be better than that! hehe
Here is a cheap and effective quality replacement pump with a CAST IMPELLER....
http://http://www.ebay.com/itm/New-130-1280-Engine-Water-Pump-/230871352035?pt=Motors_Car_Truck_Parts_Accessories &hash=item35c10142e3&vxp=mtr http://www.ebay.com/itm/GMB-130-1280...eda187&vxp=mtr GMB 130-1280 Also available in aluminum: GMB 130-1280AL http://www.ebay.com/itm/GMB-Engine-W...cc0045&vxp=mtr
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
looks pretty much like the one i just bought...
Curious as to what the pricing is with the NAPA pump? The GMB pump is the exact same one our board sponsor sells, and is a good piece.
49$
