Old 11-10-2019, 06:17 PM
gto19's Avatar
gto19 gto19 is offline
Default Oil change in safe T track rear end
I’ve never changed the oil in the stock rear end in my gto . It has the safe T Track with 390 gears . What oil do you guys recommend and how is the oil change performed ?
In. my 4 speed tranny I’m using sta lube 85-90 gl4 gear oil
Old 11-10-2019, 08:23 PM
OG68 OG68 is offline
85-90 is good but stay away from synthetics especially for the rear Safe-T Track axle.
Some claim synthetics cause the transmission to be notchy but others have no problem with it.
GL4 only for the Muncie. I remember seeing something several years ago that claims GL5 corrodes the Muncie synchros over a period of time.
GL4 or 5 for the rear axle plus the GM Posi additive.
I just drained the original oil from my non-posi rear axle a few months ago when it was rebuilt but I don't recommend 50 years between changes
Depending on how many miles you drive, every 5 years or so should be sufficient. Might even be overkill
2007 Cadillac SRX
Old 11-10-2019, 08:40 PM
Schurkey Schurkey is offline
Gotta look pretty hard to find a rear-axle lube that doesn't have Posi additive already blended in.
No need to add "more" if what comes with the lube is enough.
Old 11-10-2019, 08:48 PM
gto19's Avatar
So this stuff and a Posi additive?
Old 11-10-2019, 09:05 PM
SR-71 SR-71 is offline
What year axle is it? Is it a cone type clutch?
Old 11-10-2019, 09:13 PM
You should only need just shy of three quarts for the rear axle.
2007 Cadillac SRX
Old 11-10-2019, 09:16 PM
gto19's Avatar
1967 gto , original rear end
Old 11-10-2019, 09:26 PM
Sta-Lube multi-purpose Hypoid GL-4 85-90W gear oil. According Ray Motyka a well known 10 bolt re-builder, use 15 oz of STP engine additive mixed into the gear oil and top off the axle with the GL-4 only. The older cone type safe-T-track units do not use clutches and need the cushion of the oil or premature wear will happen.
The Following User Says Thank You to SR-71 For This Useful Post:
Old 11-10-2019, 09:37 PM
gto19's Avatar
Awesome thanks
That’s the same oil I’m using in my Muncie 4-speed
Old 11-10-2019, 09:47 PM
gto19's Avatar
So I’m assuming the 15 oz of stp takes place of the Posi additive I see at Napa ?
Old 11-10-2019, 10:10 PM
No Clutches, No Posi Lube needed.
Bill Nye.
The Following User Says Thank You to TedRamAirII For This Useful Post:
Old 11-10-2019, 10:35 PM
gto19's Avatar
How come in my 67 service manual exploded view of a safe t track rear end i see cone clutches? I’m no expert...just asking
Old 11-11-2019, 12:01 AM
The cones are what was used as clutches in the 8.2 axles back then. Ray has been rebuilding this type of posi for years and knows his stuff. Many of the stock racers that run this type unit depend on his experience to win and keep the rearend living.
Old 11-11-2019, 08:13 AM
steve25 steve25 is offline
All 8.2" posi rears in Pontiacs where cone type!
Old 11-11-2019, 10:15 AM
All years?
Old 11-11-2019, 08:11 PM
Cone Clutch is NOT the same as the Clutch Pack used for a Limited Slip type diff. I think they changed the name to Brake Cone later on.
Bill Nye.
Old 11-11-2019, 08:20 PM
mgarblik mgarblik is offline
All the above statements are correct but to summarize: The gallon jug of Sta-Lube GL-4 you pictured would be just fine in your rear axle, no limited slip additive needed because it has a cone clutch. I have never heard of using an engine oil additive in a rear end, so no comment there. GL-5 gear oil is not recommended for cone clutch type limited slip rear ends because it has the limited slip additive already in it. Won't hurt anything really, but renders the limited slip unit less effective.
Old 11-11-2019, 08:23 PM
All years?
I think Big Cars used Clutch Packs? Tempest and Firebird Cones?
Bill Nye.
Old 11-11-2019, 08:49 PM
gto19's Avatar
Once again thank you guys .
I will use the gl4 sta lube I used in my tranny
The Following User Says Thank You to gto19 For This Useful Post:
Old 12-11-2021, 02:44 PM
I'm reviving this thread because I finally got my 10 bolt limited slip installed and I'm about to fill it with oil. So to recap, 85 90 weight? Cone type clutch pack?
I already have the limited slip additive, ACDelco type. Do I not need it? Assuming it wouldn't hurt to use it since I have it?
