I had understood that the adapter was used for cars with lower gear sets; My car (not bought stock) has the correct plastic gear for the (standard) 3.55:1 gearing; I found an adapter that would be perfect for retaining the original speedo gear, and the adapter would correct for my desired 3.90:1 gearing. I would have presumed that "standard" gear set cars would not have needed any adapter.
I may have it, but may have overlooked it; I am wondering what is correct in which given application.
1970 July T/A. RAIII. 4sp original 3:55 rear gears has adapter and cable is routed over top of the trans
The Following User Says Thank You to Norwood For This Useful Post: | ||
I have a 73 4 speed formula, and both the Assembly Manual as well as the
Car show the Speedo Cable going over the Trans-Tunnel with clips on the upper Bell Housing Mount as well as a lower Clamp that I can't remember the location. Reason for chiming in hear, is another clamp I don't see mentioned. There is a welded flap (or Tang or clamp) under the Trans Tunnel (Drivers Side) that keeps the Speedo Cable from Contacting the Shift linkage. Often I see these gone with just the small Square Welded mount left over. The Cable seems unnatural as it leaves the Firewall, and make a hard turn. The natural routing the Cable want's to take is down under the Tranny, so easy to see how this can be confused. The Welded Clamp under the Trans Tunnel, keeps the Cable stationary after it leaves the firewall, and the others are to allow movement with the Drive train. These are the ones on the Trans Tunnel and the lower clamp I cant remember. Also the TH400 Cable is about 60 inches and connects on the Drivers side of the Trans. All these clamps are needed for the 4 speed as the Cable inters the Trans on the passenger side. The 4 Speed Cable is 59 or 60 inches. The Mounting of this cable is much the same as Wiring under the Hood. A clamp is used to stabilized after exiting the Firewall at a fixed point, and additional Clamps on the Drive train allow movement without effecting the Cables function or connection. |
Bob Woodard Brighton, MI 2012 SRT8 Charger - 12.70 @ 111mph |
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant http://www.ford-trucks.com/forums/12...al-ranger.html 1966 Ford F250 4x4 Red/White 4-speed - San Jose plant 1966 Ford F250 4x4 White 4-speed - San Jose plant http://www.ford-trucks.com/forums/11...-f250-4x4.html 1971 Trans Am White/Blue 4-speed limited options - Norwood plant http://forums.maxperformanceinc.com/...d.php?t=757496 |
Since this thread is hitting on cables and adapters, here is a chart showing the use of the adapter for 70 manual trans.
@ FunctionalShaker - Can you please send me a larger (easier to read) copy of that application chart?
There's a link in my profile to directly email me.
1973 Formula 400 4 spd 04C build date Norwood assembly plant. |
I have the Photo copied GM Assembly Manual for 73 Birds. Was a very nice gift
from a member. Check when I get home, but I am sure of this Cables routing as my Car was missing it's Cable, so I did a lot of research when Installing it. I cannot say how this effects other years, as I have not compared them. I think I may have steered in the wrong Direction A little, aka the Clamps on the Trans. now that I think a little Harder, this Clamp was on a trans to bell housing bolt not the Bellhousing to engine. That location is for the Wire Harnees Clamp. So this Cable exits the firewall and takes an unnatural turn to that welded Clamp then over the trans and down to the Speedo input. If the Clamps are all in the correct locations, and the Cable is the right length (59 or 60 Inches) this provides nice smooth curves on all the bends, and prevents Cable binding. In General GM or any Manufacture would never (except possible E-Brake lines) allow any Cable to track under the Drive line. Way to easy for it to get snagged. Even Front break lines although under the Engine are always shielded by the Frame, and any junction exposed will have some type of protective cover. This Speedo Cable is one of those parts that is Pontiac specific in that it enters the Pass side, not the Drivers like others. Pontiac did this to keep it clear of the shift linkage. I am much more sure of the existence and use of the welded tab clamp under the Tunnel, than I am the exact location of the other Clamps. I actually did not use the factory clamp at the lowest point (and last before the cable enters the trans.) The aftermarket Cable I used was slightly longer than the Original, so I used an extra PCV clamp from a 67 A-Body in that location as it extended further from the Trans and allowed a larger loop to help eliminate binding. It worked perfect, but is one of the few non original parts on my car. All of this is for the single piece Cable, and should not be assumed for the split cable (cruse control) as I am not familiar with that setup. Anyway I will confirm with the Manual when I get home tonight. |
Does anyone know of a source that reproduces speedo cables?
My original "CH" 4 speed cable (approx. 63" long), is in very rough shape. The outer sheath is melted and worn through in a few places. It still has the "CH" visible though. I see Ames lists some cables, but has anyone ordered one? What about fitment?
...Steve T. "Resurrection of a 1970 Trans Am" Blog www.455hota.wordpress.com ------------------------------------- 1966 GTO 4 speed Hardtop Alabama car (Marina Turquoise w turquoise interior) 1970 TA 4 speed Canadian car (Lucerne Blue w bright blue interior) |
You can get a cable from NAPA and they are around $20. As I recall, the cables they sell are about 7-8 inches too long so you have to make a bigger loop when you route it up and over the transmission to the passenger side.
1970 T/A |
I know this is an old thread, but I was putting the M21 back into my ‘70 TA today (I have another thread about running a 428 until my RA III build is done) and I had a question about the speedometer routing. I have only owned this car since 2021, so I have no way of knowing if the cable had ever been changed before, but my transmission had no adapter, but has factory 3.73 gears. I also had a clip for the speedometer, but unlike HFR’ clips, my clip was attached to one bolt on the side case of the transmission. I have no way of knowing if it was original. My cable also did not go over the top, but sort of ran alongside and looped over the tail. I didn’t pay a lot of attention to the routing when I removed it, because I assumed it would be easy to find out the correct mounting when it went back together. Silly boy that I am. I think my cable is an aftermarket NAPA version, because it seems to be longer than necessary.
Was there ever a final answer in the routing for a ‘70) and should my car have the adapter? Here’s a picture of the clip I removed. I’m not saying it’s factory, but it would strike me a bit odd that someone would add this to the car. Sent from my iPhone using Tapatalk
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone. The frogs take up where they left off. |
Yes, goes on top.
Yes adapter for a 373 car. Why on top? Simple.. speedo cable is part of the body assembly, and the drive train assembly ( on frame) was slid under it and connected . Any 355 and taller gears had an adapter. 14 or 15 inch due to being off by more that 5 mph UNDER. or more.
Ok thanks. Is the adapter available?
In FunctionalShakers pics above, it doesn’t show an adapter for 3.73 gears and F60-15 tires. Am I reading that incorrectly?
The chart could be missing rare info, which was penciled in many times, like the floor version of the assy manual
#38
Inline tube sell that cable bracket too.
