Horn Contact Grease?
I've read some posts regarding electrical and ground contacts and using dielectric grease. I need to grease horn contact on my turn signal canceling cam. Is there anything that you recommend for this? Hopefully something I have around the garage....will bearing grease, lithium, or vaseline work? Thanks
1968 Lemans Convertible Cameo Ivory, Red Interior, White Top |
white grease would be fine.
I was also wondering how a non-conductive grease would help protect and improve conductivity on terminal connections. I found these replys on the web.
It is non-conductive, but when you slide the connectors together there is metal-to-metal contact and the grease gets displaced but the area around connector is protected from moisture. If the grease was conductive it would be too easy to get "bleed" from one pin to another in a connector if the grease got hot and liquified and spread. Also, Kopr-Shield is a conducting grease that can be used to improve conductivity in bullet and spade connectors while protecting the joints from exposure to moisture, dirt, acid, what-have-you. Oddly, works on exhaust system joints, too. Available from Eastwood, 1-800-345-1178
'73 Buc Red T/A, 4 speed, A/C, Std Black Interior "If you choose not to decide, you still have made a choice" RUSH (Freewill) |
Not to hijack, but what is wrong with dielectric grease? I guess maybe it doesn't act as well as a lubricant because it is more a corrosion preventative?
Thanks for starting this thread - timely.
1967 GTO Tyrol Blue/Blk Cordova 400, TKO-600, 8.2 Posi w/3.55 400 + .020, decked to .005 SD Performance 240+CFM 670 heads RARE HO/RA manifolds RARE 2.5" Exhaust (18" Magnaflows) SD "Stump Puller" HR cam (230/236, 112LSA, 107.5 ICL) PRW stainless 1.52 roller rockers Forged TRW slugs SCAT H-Beam forged rods |
There is nothing wrong with dielectric grease. I was questioning if you could use it on terminal connections since it is not conductive and got the following response.
"" It is non-conductive, but when you slide the connectors together there is metal-to-metal contact and the grease gets displaced but the area around connector is protected from moisture. If the grease was conductive it would be too easy to get "bleed" from one pin to another in a connector if the grease got hot and liquified and spread. "" Someone also quoted an alternative from Eastwood that is conductive and also has corrosion protection.
