What are you guys using for fans/clutches/shrouds?
I put in a 4 core Champion, and it helped with cooling. I'm not sure, tho, that I still don't have air flow issues with my electric. I want to go with a mechanical clutch fan and shroud. It looks better, and will simplify my electric system.
I live in AZ, which turns into Satan's flaming anus during the summer. I will need max cool capability. I've heard of people using various HD late model clutches. And concerning fans... what mech fan? 17"? 19"? I looked at the OER shrouds for 67 FB's, and the reviews were BAD. Any recommendations for fit/finish? Thx!
Fans
I assume that more blades mean more airflow. So, since you need max airflow, I'd go with a 7 blade, in the biggest diameter that will fit in the shroud you'll be using. And of course, you can get either solid hub or clutch type.
I assume that the solid hub flex fans are much lighter than the clutch type. So, an 18", like the Flex-a-Lite, should work. They do make a lot of noise. My neighbor has offered to give me his 6 blade flex, because it make so much noise. But you need to be real careful when working with or around these metal flex fans. The blades have some real sharp edges that will cut you easily. This one got a 5 star rating at Summit. http://www.summitracing.com/parts/flx-1818 http://www.summitracing.com/search/d...rder=Ascending Or, here's a HD 6-blade that's rated to 10,000 rpm. http://mudflaps.com/i-8123062-derale...61LRoCbcbw_wcB If you prefer a clutch type, here's some fans and a severe duty clutch. http://www.ebay.com/bhp/7-blade-fan http://www.amazon.com/Hayden-Automot.../dp/B000C3F3D4 http://www.ebay.com/itm/Engine-Cooli...25.m3641.l6368 http://www.haydenauto.com/Installati...s/Content.aspx Last edited by ponyakr; 05-05-2015 at 08:46 AM. |
Shroud
Don't know if the Goodmark shroud is any better than the OER or not ?
http://www.classicdiscountparts.com/...-Firebird.html http://www.summitracing.com/parts/gmk-4320-310-67 You've probably already seen these high dollar shrouds. http://www.classicindustries.com/pro...rts/g9057.html https://www.npdlink.com/store/produc...0275-1820.html http://www.firebirdcentral.com/1967_...p/rad-2817.htm If you don't wanna take a chance on a plastic shroud, there are some universal metal shroud kits. These require some fabrication, but will allow you to use a 19" fan if you'd like, and you can locate the hole exactly where you want it. Not for everybody, but will work for some, who are not that concerned with the original look. http://www.speedwaymotors.com/Alumin...Fan,17143.html Last edited by ponyakr; 05-05-2015 at 10:03 AM. |
Doesn't the 19" flex fan cool better then the clutch fan? I thought I have read that somewhere.
Will the GM shroud fit the core Champion? I would choose it if it does.
68 400 HO 4sp Convertible Firebird400HO.com My 68 firebird 400 HO convertible Restoration Gallery |
Can't beat a 7 blade clutch fan with a full fan shroud.
My old '69 Firebird had the OE 7 blade and clutch fan with shroud (an A/C car) with a 3-core radiator and in southern California and Las Vegas heat and traffic it always held the thermostat temp, even for the short period I ran a 160ºF thermostat (I prefer the 180-185º ones). My Buick Centurion and Skylark with a 455's have the same OE setup and never an issue in traffic and triple digit outside temps.
__________________________________________ "How I learned to stop worrying and love the OHC Pontiac L6" The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!) 1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!) |
Squid
You know what I got and you know it works great. |
Found a chart online years ago somewhere?...
Had no idea how confusing it could be. Hope posted correct. Work keeps interfering! 67 V8 HD exc AC: 5 blade 19" diameter 2-1/4" pitch. 67 400 exc AC, RA: 7 blade 19.5" 1-7/8" pitch. 67-69 V8 w/AC: 7 blade 19.5" 2-1/4" pitch(thermo clutch). 68-69 exc AC, HD, RA: 5 blade 19"/2-3/16" pitch(power flex). 69 V8 HD: 7 blade 19" 2-1/2" pitch(power flex). I've had equally good cooling results back in the 70-80s with factory 7 blade 19.5" clutch and a 7 blade 19.5" Flexalite(same size blades as factory - not the skinny types) since the late 90's. Wouldnt go less the 19".Be sure to use the factory shroud with either.
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 Last edited by Region Warrior; 05-05-2015 at 12:24 PM. |
Ya, I was gonna call u in the morning, but u know I like to start conversation.
Squid- Make sure you've got a good water pump and not one with a POS stamped impeller. I'd also put water wetter in the coolant to reduce surface tension and promote better heat transfer.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
Stock 350 auto radiator.stock shroud,stock 19 blade no clutch,factory 11 bolt pump NO issue with over heating.Tom
On my 69 with AC, I use the stock fan with thermo clutch and fan shroud. It gets hot (and humid) here in Texas too. I did install a Rodney Red aluminum radiator and it made a big difference. Also, do a search for a mod to the water pump divider plate that moves the plate closer to the vanes in the wp and increases the amount of coolant being circulated.
I've already done all of the pump mods. I am running a Taurus electric fan.
I've suspected an air flow issue for a while. The electric would cool forever at idle with the ac running at 100+ temps outside, and never get over 180. Cruise would be an issue. The bigger rad helped, but it is still not where I want it. When I can keep it at 180 forever, below a tstat temp setpoint, then I will be satisfied. I want to go back to basics. I will do a hd clutch and 19" fan with stock shroud. I'm gonna try a stock shroud, and see if it fits ok. I have no hangup on original appearance, tho.
Is Rodney Red still in business? |
You could be moving the water to fast with the small pulley.
I just installed a shroud on a Champion radiator. It mounts fine on top. The bottom is a different story. The bracket on the bottom of the Champion radiator is that, just a bracket. I drilled and tapped three 3/8-16 holes. I used short screw with fender washers and some Loctite. Worked out great. |
Unless the pump is cavitating, there is no such thing as too fast. All heat transfer systems increase in efficiency/heat transfer with faster flow.
More heat out of the engine and more cool water into the engine. If the radiator isn't cooling the water sufficiently, then it's either does not have adequate air flowing through it (usually no or poor fan shrouding) or the radiator is simply too small (or plugging up..)
A shroud helps a lot with E-fans too.
On the fence about cant have to much flow. Just have 19-15/16 flex, Rodney rad., factory shroud, non a/c pulleys, 180 stat. Didnt get over 195 sitting staging lanes during 90's degree weather. I sure did sweat waiting to run though! Do some testing with a/c pulleys along with upper, lower, and side baffles when it's back together. Edit; Oh ya, water pump has stamped steel impellar....
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 Last edited by Region Warrior; 05-06-2015 at 05:37 PM. |
Get a Hayden SEVERE duty clutch. I run that, repop shroud, OE fan, and I block anywhere and everywhere the air could get around the radiator or shroud with foam insulation. I dont have those original masticated pieces but I fabbed up some black plastic block-offs to replace them. Oh, and the upper and lower sheet metal baffles of course. Results are excellent, typically with-in your wish list (maybe 185) at least until I turn the A/C on but I do run a true 10.5:1 with iron heads. Ahh, and dont forget to use some vacuum advance, it helps.
68 Firebird, trying a q-jet now. 434/10.5:1/997's/240-242 HFT/4L80E/2800 Yank/3.42's/ Vintage Air/ 13.0 @105 mph 70 Lemans, 350/350, A/C, mostly stock 14 Ram CC, 5.7 Hemi, 8-speed, 3.92 lsd 97 Trans Am, HPP Aug 2012 http://www.highperformancepontiac.co...tiac_trans_am/ ***Sold*** |
Thanks for the links. I ordered the Goodmark shroud. The OER shroud reviews pretty much stated "POS". Ames even lists it as "poor to fair". I will be using a factory style 19" steel fan, Hayden 2797 HD clutch, and some Water Wetter. I just pressed the magic buttons, so it should arrive in a few days for install. This last weekend I flushed my entire cooling system. I've had a problem with the growth of some fine rust sludge/paste. I added a few cups of white vinegar to the water and let that circulate around for a while, and it cleaned stuff up considerably. Lots more flushing, and no brown. And the radiator no longer smells like pennies and dirty feet. Crossing fingers for super cooling and summer a/c!
If nothing else, the upper baffles make for a cleaner underhood appearance!
