Old 04-18-2020, 03:37 PM
joe'sgto's Avatar
joe'sgto joe'sgto is offline
Default 1968 GTO Chrome Front Bumper Grill Trim Piece
This is the grill section between the headlights. It is a very small trim piece. I have been looking for this piece awhile now with no luck. Is this a GTO only or did Lemans grill have these too. I was out with my car and something must have hit my grill (assuming a rock) and broke it and lost it. My original one on the other side (as you can see), the coating is pealing off. I did find the grill part just missing the trim.
Thanks for any help
ID:	537734   Click image for larger version
Old 04-18-2020, 03:40 PM
Scott Thelander's Avatar
I have a couple LeMans ones
pics later today... the silver is painted on originals ... I thought ...
scott
Old 04-19-2020, 05:46 PM
Default grille parts
update
left one and 3rd one are best pair
right one is best condition
2 is 2nd best
no trim .... is that GM ? I have had over 20 of these thru the years,, broken ones painted ones ,,, never seen that trim
a better picture may help
seems odd they would do that as it wouldnt match the grilles ...
Scott
2o6 465 9165
the trick is ,,,,put a dab of gasket sealer on the slip nut hole b4 you put the part on,,, and dont over tighten... and let it set up ,,, that way the screw wont
rattle out and you wont blow the hole out of the plastic...
Old 04-19-2020, 05:59 PM
joe'sgto's Avatar
Scott,
I will call later. But do any of them have the very small piece of trim on them?
Thanks Dave
