Old 11-03-2024, 12:46 PM
Default 1973 Firebird exhaust manifold p/n's
What are the part numbers for standard 455 Trans Am exhaust manifold p/n's.
I've seen Ebay ads listing 490142 and 490149 and 490142 and 490143. The Wallace racing website only shows the p/ns for the higher performance versions.
Old 11-03-2024, 12:56 PM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
does this help? https://www.teufert.net/pontiac/exhaust.htm Looks like 490802 and 490803
https://www.teufert.net/pontiac/page2.htm
67 Firebird Convertible
Old 11-03-2024, 01:57 PM
SD73's Avatar
SD73 SD73 is offline
My '73 parts book shows 490142 and 490143 for the D port manifolds. jwcfbd's numbers are correct for SD heads.
The Following User Says Thank You to SD73 For This Useful Post:
Old 11-05-2024, 05:41 PM
unruhjonny's Avatar
standard exhaust manifolds have been for the last thirty(?) years quite overlooked;
When I first came to realize this, I also found that getting hard information on numbers ect was quite tough.
I have a small collection of them and am happy to share the casting numbers that I believe to be applicable:
drivers: 490149 (my example is from a 1974 model year casting)
passenger: 490142 (I have both 1973 & 1974 model year dates; I have this casting number even in a 1976 calendar year date)
As far as I can recall, I have had several drivers side manifolds have the bolt bosses break in half from trying to remove damaged or broken studs - so I currently have more passenger side than drivers side;
I believe I have more variety in drivers side casting numbers.
By 1977, both sides used three exhaust manifold to exhaust pipe studs;
In 1973 they still both used two studs per side.
1970 Formula 400
