Booster Spacers
I just wanted to take a moment to thank the PY forum community again as the forums have once again proved to be an invaluable resource! I recently began a rear end swap on my 1970 LeMans coupe and ran into a curious situation when attempting to preload the new rear springs and control arms. No matter how I tried to attain the proper clearance between the axle tube and frame I was no where close to the measurement in my assembly manual. Everything looked normal. After all, I pulled the axle assembly out of a 1969 442 that I parted out 20 years ago. I had disassembled the rear, replaced all the bearings and seals, even cleaned and painted it. I tried compressing the new springs by lifting the axle from the center with a floor jack - no dice! With the shocks disconnected the whole car would lift off of the jack stands, and I still couldn't set the axle any closer that 7-8 inches away from the frame rail. The specification calls for 4.68 +/- .25 inches. WTF? This has gone on for a couple of days, with valuable spare time expended. I then did what I should have done in the first place, searched the forum for info! Sure enough I found this thread, and I might not have even stopped to read it, but then I saw Greg's picture of those "booster spacers" that he found under his rear springs. Zow! They look just like the ones on my axle. I would never thought to even question those - they were as dirty and corroded looking as the whole axle assembly! I live in the northeastern part of the country so everything older here usually has a slightly rusty patina.
So it looks like I'll be headed back out into the cold garage to remove my recently installed axle, new springs, and at least the upper control arms, so that I can get those old speed shop spacers out of there! Gee I wonder if that's why my 1967 GTO sits high in the back as well? Yet, another job for some other day. Thanks again to all who participate on this forum for lending me your knowledge, and common sense, it is truly invaluable the older these cars become. Shiftydr |
Greg Reid Palmetto, Georgia |
