Old 11-30-2013, 05:14 PM
speedfreq's Avatar
speedfreq speedfreq is offline
Send a message via Yahoo to speedfreq
Default Axle bumper? 70 TA
Looking for a source or ideally an actual part. When my car was stripped it looks like the middle bumper for the pumpkin was lost or discarded. I ordered what I thought was the correct piece from one of the parts warehouses but it look like I need something that actually bolts to the floor pan and this one just pushes in. If anyone has one or a source please let me know, doesn't need to be beautiful or NOS
Chris
Like the sign says, "speed's just a question of money. How fast can you go?
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
Albert Einstein
Old 11-30-2013, 06:06 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
there's a nice used one in this set for later 2nd gens. The snubber that you need is the same as the early years but the outer snubber set in the auction are as stated for '75 and up.http://www.ebay.com/itm/1975-1981-Ca...b3fb8d&vxp=mtr
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 11-30-2013, 06:19 PM
Tunas73TA's Avatar
Tunas73TA Tunas73TA is offline
I assume you're mean this one?
Not sure there is a difference in any of the 70-73 models
But there is a difference in the end bumpers..
chuck...
1973 455 TA (07A)
Old 11-30-2013, 07:31 PM
70RAlll 70RAlll is offline
The side snubbers for 1970 did not bolt in, they just had a rubber piece snapped into the steel bracket ,1971 started using the ones shown here with the single stud to bolt in. The center piece, which is what I think he is asking about, is attached to a rectangle strip of steel with two 5/16" screw holes that mounts to the center above the rear ends center section.
Old 11-30-2013, 07:41 PM
I had not looked at Rick's link before commenting.Rick is correct, that is the center snubber you will need. $35 sort of sucks, but I don't believe they are reproduced correctly.. May be, just have not seen one..
speedfreq's Avatar
Yep that's the one, I do already have the end correct end bumpers just need that middle one.
Thanks for the link Ricks now I know what to look for.
Albert Einstein
Old 10-22-2014, 08:36 PM
FunctionalShaker FunctionalShaker is offline
I'm in need of a single 70 style side snubber -- just the rubber bumper part. I posted in the parts wanted section, but not everyone always goes there.
Old 10-25-2014, 10:35 PM
Seriously, nobody's got a stray they can part with?
Old 10-25-2014, 11:06 PM
your picture of the side brackets,the set on top, may be correct for 72-73, but it is not the style 71's had. 71's looked just like the 70 metal part, only the rubber used a single stud/nut to attach vs 70 style with just rubber.. i guess the set you show came from a 73??
Old 10-26-2014, 09:14 AM
Here's what I need -- just the rubber.
Name:	Axle bumper.jpg
