Old 07-02-2019, 03:53 PM
Bermuda Blue Bermuda Blue is offline
Default Spring shim dimensions
What are you guys using for spring shims?
Looks like a D port head would use a shim with no less that a 0.667" ID and no more that a 1.473" OD. Can't find anything that would fit those dimensions closely. Any recommended part number would be appreciated.
Old 07-02-2019, 10:32 PM
tc's Avatar
tc tc is offline
Crane 99050-1
https://www.amazon.com/Crane-Cams-99.../dp/B000CC9AIO
Old 07-03-2019, 11:39 AM
Originally Posted by tc View Post
thank you
Old 07-03-2019, 02:13 PM
gtofreek's Avatar
gtofreek gtofreek is offline
An A-303 or a B303 is what we use on Pontiac heads. Fits pretty good. The A and B in the number is the thickness. A = .060", B = .030".
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
