Old 02-14-2020, 01:39 PM
rustyrelic rustyrelic is offline
Default Are the full size 65-70 Pontiac manual shifter rods specific, maybe shared?
I didn't want to muck up the 68 4spd cat postings, but have a question:
Are the full size 65-70 Pontiac manual shifter rods specific, or were they maybe shared with other GM lines? For instance, there is an Ebay listing for a 68 impala linkage - https://www.ebay.com/itm/NOS-Hurst-4...cAAOSwt35d2FfL
would this work with the 68 full size Pontiac?
Old 02-15-2020, 02:14 AM
Scott Thelander's Avatar
here my vision
if its a 68 tranny with studs and nuts holding the levers on
AND
your using a HURST comp plus shifter
AND
you have the correct shifter porch or mounting plate
I would order a set of repop 67 68 GTO linkage and levers and hardware
they sell 67 68 as the same but they are bent different but it will work the best in your application
if you have bolts holding the levers to tranny (69) up
order a 69 set
Scott
