Romac balancer
Looking to build a 450-500 HP ?? street motor.
Is Butlers Romac acceptable or is there something better ? Throw out your pennies gentleman. Thanks, OGR
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
What RPM range is it tuned for? What RPM range are you likely to spin that engine?
I dont think it will be anymore than 6000
Block is still in the shop
Very nice balancers. Have one on my 400 w stock pan which needed a little work. Have another on my 467 w aftermarket pan that I shift at 6k.
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
Just keep this in mind, the bigger the stroke, or the more rpm, or the combination of both calls for a heavier then stock Balancer, HP levels have nothing to do with it!
This very true for a cast Crank motor where you want to keep from forcing it to have to flex! The balancing of the Crank itself is where HP levels ( cylinder pressure levels ) and other factors are dealt with as best as possible!
I thought the romac had fitment issues, like hitting the pan lip and timing cover, and pulley bolt pattern? I used the Pro/Race 64275 SFI unit, fits like stock but is 9lbs and is SFI rated. Have not fired the engine but it fit perfectly.
I have one and looked nice in the box but had issues also with figment. It was 0.0015 to small. That was a pain to get rectified. Next as mentioned had to grind the timing cover a little not impressed. I would think that some type of information sheet should have been provided on modifications. The vendor I used said ya this is common.
It is nice unit but be prepared for a little work. |
I posted in the other thread. I have used the Romac for many years on my 421 combos. Spin it 7200-7300 every time out. Never had an issue. Did have to bend the lip pan a small amount.
I have 3 of those on 3 different motors.
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" Last edited by Old Goat Racer; 02-15-2020 at 11:50 AM. |
I've ran the Romac balancer for years on my street car with a stroked 400(461), and have never had an issue. I have the Romac that is Steel with the Aluminum outer ring. Very nice balancer in my opinion, and fit great, it did require just a tiny bit of bending of the lip on the front of the oil pan, but is a super easy fix that can be done in a few minutes. I also run the billet Rollmaster Timing Set(same company), very nice as well, and uses the IWIS chain.
1978 Trans Am Pump Gas 461 Stroker |
You may also want to consider a Powerbond SFI balancer. It's also a nice piece. I have one in a 500 hp street motor for 7 years and no problems. Fits perfect and accepts stock pulleys.
A second on the Powerbond SFI.
Are Pioneer balancers any good? Specically the Pioneer-872011 street balancer and the Pioneer-872031 race balancer. Thanks, all.
"No replacement for displacement!" GTOAA--https://www.gtoaa.org/ |
