Old 08-13-2019, 01:17 PM
Tim66 Tim66 is offline
Send a message via ICQ to Tim66
Default body mounts
I thought they were all the same size.I did mine on a 66 lemans about 8 yrs ago.Seems to be fine.
Good luck
Tim
Old 08-13-2019, 06:11 PM
Old Goat 67's Avatar
YES, 2 ".
Old 08-13-2019, 07:19 PM
GT182's Avatar
GT182 GT182 is offline
Yeah, I apologize. 2" as Charles says.
When they get squashed over 53 years of time they seem larger than what they really are.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 08-13-2019, 09:37 PM
Check out the picture I posted of the mounts all laid out, it’s easy to see they’re all the same diameter.
Old 09-24-2019, 09:51 PM
GT182's Avatar
Yep I checked. I still haven't done the swap as the original bolts kit from Ames is on back order. I refuse to get them from any place else.... especially OPG.
I've been driving the GTO, and as long as I keep 30#s of air in the airbags all is good... so far.
Gary
Old 09-24-2019, 10:55 PM
MUSLCAH MUSLCAH is offline
Nice write up Bart.
Old 09-25-2019, 05:50 AM
Jeff Hamlin's Avatar
Cool JUST FOR GRINS,
Thought I would throw in a few related old bits;
Old 09-25-2019, 09:27 AM
Cardo's Avatar
Cardo Cardo is offline
The bolt kit Ames sells is from AMK. You could just order directly from them. $33. I've bought several different bolt kits from Ames, all of them have been from AMK.
Old 09-25-2019, 11:22 AM
OG68 OG68 is online now
I used Ames (bolts) for my 68. But they didn't supply the short bolt for the #3 position. Had to reuse my original.
For those seeking originality, I have found that the colors of the upper bushings seem to be dependent upon assembly plant. I had painted the upper bushings with what I thought (at the time) were the correct colors. But with so many examples on the web each with their own paint scheme it was confusing to say the least. So I dug out my old bushings and looked a little more carefully. What I found was all the upper bushings were black, but all the lower bushings (donuts) were at one time painted lavender. This was a Fremont car built on an A body assembly line. All the original bushings with the exception of the rears had TEMP molded into them. The rears had CHEVROLET and a Chevrolet part number. This is also noted in the service manual. The red paint shown is overspray from the car body.
Inline Tube is the only vendor I know of that goes into this level of detailing.
ID:	520884   Click image for larger version
ID:	520885   Click image for larger version
2007 Cadillac SRX
