Air vent pull knobs, replacements?
I'm noticing that the knobs under the dash in my '66, that you use to pull open the air vents (non-A/C car) have faded chrome and now look like black plastic. Has anyone ever switched them out? I'm just wondering how to remove them without damaging anything and if replacements are available.
As I remember replacements are readily available. I replaced mine on my Firebird. The old ones just crumbled when I removed them. When I installed the new ones I put epoxy in them and pushed them on, still good after ten years.
69 Z 302 M21 3.73 http://www.byjanmarie.com/camaro/Z28.html 69 FB 400 http://www.byjanmarie.com/firebird/69.html 69 Camaro 327 4sp. 4.10 http://www.byjanmarie.com/camaro/69camaro.html ( SOLD) 2002 Camaro LE/SLP-(sold) 1967 Nova SS-- 327, M20, 3.73, FRT Disc |
My originals are so old they're white. The replacements are chrome plastic and are really replacement radio knobs, but look pretty good. I have a set but haven't put them on yet. I want new kick panels first. Just make sure you either use a really good glue or heat [not too hot] when you push them on. I was told to use heat but be very very careful.
Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
IIRC just like the parking brake handle they are pushed onto a barbed shaft thus making them almost impossible to remove without damaging.
I always use a dremmel type tool to cut them off and be done with it. FWIW the metal radio knobs make a nice substitute for the old electroplated chromed plastic ones.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
Thanks Jeff, that info is good to know. Now I can change mine and no worry about them coming off. No glue, No heat.
As Jeff stated, I too used the chrome radio knobs as replacements. Looks great and easy to get and attach.
I don't mind the chrome reproduction plastic knobs for the air vent pulls, but not on the radio.... unless it's absolutely necessary. The metal radio knobs to me are a must for the radio. And it's too bad that no one can make them. Actually it's the same thought for all the dash knobs.
GT182: Leave the radio knobs where they are...go to a swap meet and buy original radio knobs..use them as replacements for the plastic vents. Radio knobs are fairly easy to find.
Troy, we don't get many swap meets around here with Pontiac parts, let alone parts for a 66 GTO. Tho I'm always looking. So for now plastic will have to do.
FWIW;
RESTOPARTS offers '66 METAL dash knobs. Jegs has them listed.
Certian 68 radio/dash knobs are exact to the vent knob.
Pull old vent knob off. compare to your stash of Headlamp or radio knobs Carefully press nice knob on |
No Pontiac swap meets!?!?!? Move to Ohio they have huge Pontiac swap meets
Thread Tools | |
Display Modes | |
