Old 10-13-2019, 08:49 AM
potentpontiac's Avatar
potentpontiac potentpontiac is offline
Default 50mm Roller Cam Bearings
In my Ia2 Aluminum Block I have 50mm Roller cam bearings. I am using the Simms Timing deal with Torrington set up.I have noticed some very minute shavings in the oil, Non metalic.I don't think the front cam bearing has any positive oil feed to the thrust side of the cam plate. Is it necessary to have a small groove in the block to feed oil to the thrust area. I haven't pulled the timing cover to see if there is any wear. Also to check Cam end play. It was my understanding that the other roller cam bearings are pressure fed with oil.I wanted to know if Mods are required to the front only area of the Block to feed positive lube to the Cam plate. Any Info on this would be appreciated.
Old 10-13-2019, 09:24 AM
Richie Hoffman's Avatar
Richie Hoffman Richie Hoffman is offline
i would get some oil to the thrust plate
2008KRE Q16 Winner
2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam
Hoffman Racing building and racing Pontiacs for 35 years
Old 10-13-2019, 09:55 AM
chiefbigb chiefbigb is offline
I put a small slot going from the oil hole the block forward so oil could leak under the bearing to the plate.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
Old 10-13-2019, 10:16 AM
I suspect that might be the issue. Will have to take a look.
Old 10-13-2019, 10:54 AM
mgarblik mgarblik is offline
That's what we do. First use of roller bearings years ago we lost a thrust plate on the dyno. (Non-roller plate)
Old 10-14-2019, 12:23 PM
Confirmed there is oil feed to the thrust. I wasn't sure because my short block was done at Butlers.
Old 10-14-2019, 05:03 PM
aaronman aaronman is offline
We also had to get oil to that area. I posted on this awhile back.
Old 10-15-2019, 11:24 PM
lust4speed's Avatar
Photos? Trying to visualize where the oil slot or hole would be added?
Mick Batson
