Old 10-06-2022, 11:16 PM
Question TH400 Straight-Cut Planetaries Stronger or not
Does anybody have data on the TH400 2.48, 1.48:1 Straight-Cut gear strength in the 1/4 mile use?
To me they appear more efficient, but the Straight tooth appears to have more load across less tooth are?
Might make a nice loud 1st & 2nd gear noise on the street.
Never busted a stock helical planetary, nor seen a 1/4 mile run bust the stock helical planetary. Seen a cooked planetary set from a core that had > 45 minute continuous 2nd-1st gear ride limp home.
Old 10-07-2022, 02:11 AM
Scott65's Avatar
Scott65 Scott65 is offline
Thrust load should theoretically be better with the straight cuts. Maybe less likely to cook bearings?
The Following User Says Thank You to Scott65 For This Useful Post:
Old 10-07-2022, 09:36 AM
Yes, near-zero Thrust loads on all the HD-Torringtons is the low-hanging fruit, for MPG.
Helical-Cut Sun Gear just looks way stronger for TQ-Transfer, and Wheel-Hop shock levels.
Old 10-07-2022, 10:30 AM
mgarblik mgarblik is offline
Not a scientific answer, but the factory went to the straight cut gears in 1 ton and heavier applications of that transmission I believe. Since they are more noisy, extra strength seems to be the only reason they would have gone to that design. Just my observation. How much stronger? People racing them hopefully will chime in.
The Following 2 Users Say Thank You to mgarblik For This Useful Post:
Old 10-07-2022, 09:42 PM
Shiny Shiny is offline
Seems you already know the helical gearset will be stronger in "bending" normal to the teeth if all else is equal. That will follow shared loads across multiple teeth in the helical. But if the dominant fail mode is bearing or case failure from thrust loads, then clearly the helical loses. Maybe the truck example supports that?
But your question is interesting. Assuming a straight-cut was chosen for "efficiency", would it still have enough strength margin to handle the abuse of a race car?
My guess is the materials for an aftermarket straight-cut might be stronger than OEM helical so apples to oranges may be part of the answer.
Old 10-08-2022, 08:44 AM
@ Shiney Yea, we heard alot about M22 straight-cut gears, yet i was fine with the M21 HD, As for TH400 also fine with the helical cut and case loading because the High Density Torrington are slippery under thrust loads. Far as i recall Strong Steel modulous and Yield strength is a tight grouping across the alloys.
Any racers insist on the straight-cut planetarie for the TH400 ?
I have seen photos long ago the non-stock ratios (numerically lower 1st gear) loosing teeth in the 1/4 mile. Pretty ure those were traight cut teeth.
Old 10-08-2022, 09:14 AM
Heavy truck transmissions Eaton Fuller meritor ect. In the main case use straight cut gears but in the auxiliary/ rear box use angled teeth. I know some power train engineers in my field. Good question to ask them
The Following User Says Thank You to chiefbigb For This Useful Post:
Old 10-08-2022, 10:53 AM
"Successful engineering is all about understanding how things break or fail."
Henry Petroski
Originally Posted by Half-Inch Stud View Post
... helical cut and case loading because the High Density Torrington are slippery under thrust loads.
That's a good point. Maybe helical gears have more "sliding" motion along the tooth contacts? If so, I guess wear at the contact surface could be another failure mode influencing the design decision. As I recall, no gear is "perfect" WRT rolling vs sliding
Far as i recall Strong Steel modulous and Yield strength is a tight grouping across the alloys....
Yes, all steel alloys share the same elastic modulus but there can be big differences in yield and tensile strength.. typically correlated with cost! To me the answer to your question can't be answered without knowing "how it fails". If it's overstress from impact loads (ie "dump the clutch"), then "toughness" properties of an alloy will be important.
If the biggest risk is fatigue failure, then tensile strength is important but so is design and processing (ie stress risers, residual stress, microstructure). I'll have to look up the differences in tooth profiles between helical and straight gears. Maybe it's hard to keep the tooth stress the same when the ratios are the same?
Based on your descriptions and comments from others, it sounds like thrust loading of the case and subsequent thrust bearing or case failure may be the practical concern when helical gearsets get overloaded.
Cool! Will be interesting to hear what they say if you think of it.
Old 10-08-2022, 06:16 PM
ErikW's Avatar
ErikW ErikW is offline
If you have them, use them but not worth trying to find them. They are a bit noisy also.
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
Old 10-08-2022, 09:33 PM
Thus far, i plan to tell the fella the helical setup is a freebie, unless he wants the noise of straight-cut gears.
Old 10-09-2022, 12:58 PM
Formulas Formulas is offline
when i took apart my 1968 GTO th400 one of the thrust washers was gone from one helical gear and there was substantial wear in the drum from helical side loading, tossed that sucker decades ago
Old 10-25-2022, 06:18 PM
taff2's Avatar
taff2 taff2 is offline
We like to use the st cut factory gear sets in our TH400 builds if they are available- trouble is,they are in short supply now and pretty expensive.
We have one st. cut set in a customers 6000lb LWB Chevy race truck, with a 632 cu in BBC and Procharger it makes around 1600hp. It has run flawlessly for the past two race seasons apart from the stock output shaft snapped. We renewed that with an aftermarket 300M shaft, changed the low roller sprag and checked out the rest of the trans - the factory st. cut gearset was perfect.
Also have another st. cut set in a 4000lb twin turbo small block street/ strip van, has run flawlessly for the past three seasons, 9.40@ 142.
Look in the big Chevy powered motor homes and trucks for a set, usually if the trans has the large drum brake on the rear of the trans case -it has the st.cut gear set.
The Following User Says Thank You to taff2 For This Useful Post:
Old 10-25-2022, 11:08 PM
@taff2 thank you, as that is the only data for me to go by. Boosted-engine data is definitely a Higher TQ load than any NA engine TQ output.
Yea, i got the rear drum brake tail kit with it.
Old 10-26-2022, 05:31 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Straight cut gears are stronger than helical gears. They have more tooth contact area for better load distribution. They consume more power due to friction. They are also louder because they kinda crash together vs. rolling together progressively.
