#61
Those are the coolest gagues I have ever seen!
Great job so far, the paint is amazing as well!
Jason Rackawack 1975 455 Trans Am - 1975 Firebird 400 |
#62
Amazing!!
#63
I see you have pics of 17x9 snowflakes and stock snowflakes. Which
wheels are you going to put on it? I am helping a buddy build a modified 79 T/A right now and he purchased the 17x9 wheels for the car and when we went to install them we discovered that they have much thicker shanks than stock snowflakes and the lug nuts were onlly catching a couple of threads on the studs. We had to change out all the studs on the front hubs and rear axles to new studs that were about 4 threads longer than stock. If you are planning on swapping wheels back and forth from stock to 17x9 you are not going to be able to do it, because if you put the longer studs on for the 17x9 wheels, the lug nuts are going to bottom out on the studs when you install the stock wheels. We talked to Year One about the problem and they acted like they never heard of it. I can only assume they are driving around with the lug nuts holding on the wheels by two threads.....INSANE! |
#64
So, you're saying the depth of the lug nut holes in the Year One snowflakes is deeper than factory?
Steve F. |
#65
Doug nice work my friend.
Conrad 79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers. |
#66
thanks Conrad, if you make it to Dayton this year, I'll see you then.
thanks its still a work in progress. just wait till you see how the birds/decals went on.
started the drive line today.
I had to mod the hot air exhaust stove to fit the RARE manifolds.
Lester,
Look'n good in the neighborhood!!! I know there's a lot of different Pontiac engine colors. Which one, and part number is that one??? It looks like what came on my engine.
#71
http://www.eastwood.com/ew-ceramic-e...m-corp-bl.html
Eastwood's Ceramic Engine Paint , GM Corp Blue used on 77-81
Can one of you all measure the lugnut hole on your new 17" (or 15") snowflakes. Will probably be around .735-.745. I'm trying to back some bushings for 1/2" lugnuts and snowflakes but mine are originals and various wear on the holes. Mu factory lig nuts are 0.700 but the wheels are hub centric-my aftermarket axles need lugcentric to center them.
#73
update sorry I've been slacking on the pics
got the new brake lines on from in-line tube.com and had the front turn light bezels chromed
but I did have some problems with the clear. PPG fixed the problem. the bad part was I had to re-paint the car. I'll have pics of the new paint posted soon.
Holy crap, Batman!!!
#76
let me know what y'all think of this color.... Lori and I wanted it blue from the start. just thought when I sold it , a Black ta would sell alot quicker then any other color. so now that its not for sale and when I picked up the new paint I got the marty blue and added pearl into the color. the pearl really makes the blue pop and change colors as you walk around the car. we really like it.
here is a few pics. I really hope I dont get doged for a 78 color on a 77. Bones saw it last night and I think likes it. just paint no clear cleared wet sanded first buff not polished yet. started getting it back together
Crap, I like it!!!
A good looking paint job makes the car, this one makes the car!!! Not to different from Lucerne Blue Does the flex additive, for the nose and tail, still affect the color, like they always seemed to, in the past???
#79
I dont use the flex additive , its a 50.00 rip off. urithane stays like rubber for a few days. long enough to get the bumpers on.
