Old 07-04-2014, 03:37 PM
Deadhead's Avatar
Deadhead Deadhead is offline
Default '66 A body Vs B body bucket seat kits
Are the foam biscuits for '66 A body and B body buckets the same?
And, is there a way to eliminate the old wire structure and use all foam or more modern cushion set-up on the bottom?
Thanks for any help
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
Old 07-06-2014, 10:47 AM
irgoatmike irgoatmike is offline
I'd say that the easiest way to get what you are looking for is to find a set of modern buckets at the pick n pull and fit them to your car. I took an automotive interior class this Spring and gained a lot of respect for interior upholstery guys. Irgoatmike
Old 07-07-2014, 09:20 AM
Deadhead's Avatar
Want to keep original looking buckets. Looks like the foam kits I have seen for A body are vast improvement over factory.
-LBJ
66 Bonneville wagon
Old 07-07-2014, 03:38 PM
brut4s's Avatar
brut4s brut4s is offline
Try these guys
http://www.tmiproducts.com/
Old 07-08-2014, 01:54 PM
fatguyterry's Avatar
fatguyterry fatguyterry is offline
I think b body seats are a little bigger. I know the floor tracks are bigger. but I think you could make them work
Old 07-11-2014, 08:30 AM
Deadhead's Avatar
This is what I was thinking too.
Thanks for the link
-LBJ
66 Bonneville wagon
Old 07-11-2014, 10:43 AM
GT182's Avatar
GT182 GT182 is offline
The B's seats are a completely different animal. You need the wire springs in the framing to keep the foam and yer butt off the floorboards. With the foam you eliminate the burlap and cotton padding that originally came in the seats.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
