Old 07-28-2021, 09:08 PM
gogtogo's Avatar
gogtogo gogtogo is offline
Default WIX 51258 Oil Filter
Getting ready for Norwalk today and changing oil in my 64 goat and noticed my filters bottom was blow down. 462 @ 748hp, can anyone recommend a cure? 20/50 Penn Grade oil. Oil pressure is 80-100psi at cold start so I use a heating pad on the oil pan to preheat the oil.
Old 07-28-2021, 09:42 PM
tom s tom s is offline
thinner oil!Tom
Old 07-28-2021, 09:46 PM
GTOGEORGE's Avatar
My buddy has that in his BB Chevy and don’t have a problem. 80-100 is high for a Pontiac….you only need 10 lbs of oil pressure per 1,000 rpm!
GTO George
Old 07-28-2021, 10:12 PM
gogtogo's Avatar
Aluminum Rod Engine which is why I’m 20/50. Yes, I know all about Pontiac’s needing only 10psi per 1000 rpm, but this is what I’m dealing with. Is a alternative filter an option, perhaps a WIX race filter?
Old 07-29-2021, 01:05 AM
Richie Hoffman's Avatar
Richie Hoffman Richie Hoffman is offline
k&p engineering makes a reusable filter
2008KRE Q16 Winner
2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam
Hoffman Racing building and racing Pontiacs for 35 years
Old 07-29-2021, 09:47 AM
Mike Davis's Avatar
Use the K&P, best filter out there. Wix quality has went down hill recently. Had one on my Duramax come apart on the inside and clog the inlet and a friend had one on a Buick drag car come apart on the inside and lose oil pressure.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 07-29-2021, 09:51 AM
leeklm's Avatar
leeklm leeklm is offline
How about the Fram HP race series filter? Extra heavy case, and has an internal bypass valve, which is covered by a mesh screen over the bypass to keep the big chunks out...
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
Old 07-29-2021, 10:41 AM
Steve C. Steve C. is offline
If interested System-1 makes a "Spin On" Billet oil filter with a 35 micron screen.
https://system1filters.com/product-c...y/oil-filters/
Most WIX Racing filters have a 28 GPM flow rate and 61 Nominal Micron Rating
https://www.wixfilters.com/Speciality/Racing.aspx?1
Old information here:
73LeMans's Avatar
73LeMans 73LeMans is offline
I'm using HR2 10w30 in a similar build (462, 700hp?, 100psi on initial fire). Same filter and I may be experiencing the same issue. Can't really tell the filter changed dimensions at all, but put a caliper on it, and it appears the filter grew a few ticks under 1/8th of an inch. About 300 miles on it. First oil change with any real use, so cant draw any conclusions yet. Will see how the others go. No bypass on my remote system, so its why Im being so careful here. Not sure it means I need a $175 oil filter yet, but that K+P S16 sure does look nice!!
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....looks like 2023 as well.
>>My 73 Build thread
The Following User Says Thank You to 73LeMans For This Useful Post:
Old 07-29-2021, 10:56 AM
GTOGEORGE's Avatar
You can buy a used systems one cast aluminum screen filter for around $100 or less on eBay.
GTO George
Old 07-29-2021, 11:06 AM
chuckies76ta's Avatar
The Wix racing filters are rated at 500 psi burst rate.. Check it out. https://www.wixfilters.com/Specialit...%20Catalog.pdf
I run Wix with no issues. 51069R racing filter.
Old 07-29-2021, 11:07 AM
Scott65's Avatar
Scott65 Scott65 is offline
The System 1 will hold the pressure, and will flow better, at the expense of slightly less filtration.
Old 07-29-2021, 11:36 AM
GTOGEORGE's Avatar
You can get different micron rating with the screens.
Mine is 40.
GTO George
Old 07-29-2021, 12:07 PM
73LeMans's Avatar
Minor point, slightly off topic - Good link! FYI, Summits listing for that filter is incorrect - it has the 51069R at a 225psi max pressure.
I like the 51069s bigger diameter gasket. Not sure it will help - same GPH - but sure cant hurt.
Mark S
>>My 73 Build thread
Old 07-29-2021, 12:17 PM
73LeMans's Avatar
Apologies - 51258 and 51069 have the same GPH, but 51258 and 51069R do NOT. Initially the Wix filter page didnt return a listing for the 51069R, so I thought it was the same as the regular 51069.
Mark S
>>My 73 Build thread
Old 07-29-2021, 07:32 PM
gogtogo's Avatar
Thanks for all the input fellas. Very helpful information and greatly appreciated! I will be ordering a reusable after Nationals.
Old 07-30-2021, 07:13 AM
taff2's Avatar
taff2 taff2 is offline
I've run ali rods in my Pontiacs with around 80-100 psi cold start pressures, I used to heat the oil pan with a small electric fan heater before I started the car after leaving it stand for a few weeks . I've always used Fram PH4825 oil filters ( no internal bypass valve - I want all my oil filtered,all of the time!), and never had a problem with them. I have used the Champion, Wix and Mann equivalents of this filter but prefer the Fram as it has more oil hole area in the top plate.
The Following User Says Thank You to taff2 For This Useful Post:
Old 07-30-2021, 11:32 PM
adynes's Avatar
adynes adynes is offline
Can you post a picture?
Old 07-31-2021, 07:10 AM
gogtogo's Avatar
Adynes, the filter was cut apart and inspected by the builder and myself. The filters bottom grew about an 1/8” but everything looked fine inside. We are running this weekend at Nationals.
