Old 03-12-2023, 09:19 PM
GoreMaker GoreMaker is offline
you didn't really hijack anything, I'm still trying to figure out how to reassemble this heater box, too!
I'm pretty sure I've forgotten to re-install a spring or two somewhere. Is there supposed to be a spring at the defrost door? How does it attach?
Old 03-13-2023, 12:27 AM
Trevor78 Trevor78 is offline
There's a return spring already built into the arrangement of rigging where the levers are, where cable attaches. There's also a return spring that holds the defroster/floor door sealed when not under vacuum.
Old 03-13-2023, 12:30 AM
Thank you, I think I forgot that second one. Somehow I need to figure out which of the leftover springs goes there...
I really wish there was a reassembly DIY with pictures somewhere. This heater box was a mess when I got to it, so figuring out how it's supposed to go back together is a nightmare.
Old 03-13-2023, 12:49 AM
i4abuygto's Avatar
i4abuygto i4abuygto is offline
Mine is out and I didnt take anything apart - what photos do you need?
Attached are a few photos of the levers and spring for the defrost door. The side of the spring on the defrost door that you cant see attaches to an existing hole on adjacent side aluminum plate.
Name:	back side of ACHeat cannister.jpg
ID:	608789   Click image for larger version
Name:	Backside of defofrost cannister.jpg
ID:	608790   Click image for larger version
Name:	Lever on top AC-Heat cannister.jpg
Old 03-13-2023, 01:06 AM
I'd love to know which spring is used to keep the defrost door closed when vacuum isn't applied to its canister. That's the long door that's mostly horizontal. I also need to know where it attaches to that door. I've figured out where the other end of the spring attaches on the sheet metal part of the housing.
Old 03-13-2023, 01:07 AM
i4abuygto's Avatar
I edited my last post with photos.
Old 03-13-2023, 06:52 AM
Good pics. See first and 2nd for spring on door flap that keeps it shut, vacuum pulls it open. The staples normally hold a sponge foam seal onto the door, always long gone.
3rd pics you can see the spring at top right on the pivot post.
Old 03-13-2023, 08:07 AM
THANK YOU! That helps enormously
Old 03-13-2023, 01:56 PM
i4abuygto's Avatar
I am trying to figure out the vacuum system as I do this. Perhaps someone can help me with what is necessary and what is not.
I have a 403 that runs pretty strong but I acquired it with much of the vacuum components disconnected as an aftermarket edlebrock aluminum performer manifold and 750 Holley carb were added.
I have found in fixing all that the vacuum advance on the distributor is not hooked up. Nor is the charcoal cannister, any of the vacuum lines associated with the air cleaner (except the main line down to the valve cover), or the small vacuum line that controls the AC system that is supposed to have a check valve in line somewhere.
After market chrome valve covers are also added.
I have attached two photos of the basic 403 vacuum system. The first photo is one that I found for reference - the second photo is edited to show what is not hooked up on my system (circled in red) - is not hooked up - the yellow shows only the manifold vacuum going down to the transmission and that is all that is currently hooked up to the manifold vacuum.
My brake booster is to the rear base of the carb and noted in Blue on the second photo.
I have to fix the vacuum system - I have a vacuum port open on the front base of the carb that I believe to be ported. I think I need to plug that line and run the distributor, transmission and AC controller off of the Manifold Vacuum - is that correct?
Where do I connect the check valve and the AC controller vacuum line to the system?
What is necessary on all the other components not hooked up and what is the simplest way to include them if they are necessary? Can I bypass or remove the cannister?
Do I need to start a different thread with this topic?
Please advise.
Thank you.
Name:	Vacuum Diagram (1).jpg
ID:	608799   Click image for larger version
Name:	Vacuum Diagram 2.jpg
Old 03-13-2023, 02:20 PM
Those are all engine and emissions diagrams, the simple vacuum for dash controls come off the rear intake runner port.
Start a new thread, that sounds really messed up. Whoever carried out the carb swap obviously didn't know what or why they were doing it, which is nearly every carb swap.
403 olds intake vacuum checkvalve (2) by Ben, on Flickr
403 olds intake vacuum checkvalve (1) by Ben, on Flickr
Old 03-13-2023, 02:40 PM
Right. All the heater box vacuum comes from that vacuum check valve, and gets distributed through the interior by the climate control unit.
What you're referring to is the underhood vacuum system, which is completely separate from the heater box and climate control. In my case, I eliminated almost all of it, with the exception of a vacuum switch that sends ported or manifold vacuum to the distributor (depending on coolant temperature), the PCV valve (which goes to a dedicated port on the carb), and the charcoal canister (which j'ai goes to a dedicated pet on the carb). Beyond that and the heater box, I've blocked off all other vacuum because I no longer run a vacuum brake booster or any other emissions systems.
If you need info on the underhood system, you'll need to start a new thread in the Street Engine category of this forum
The Following 2 Users Say Thank You to GoreMaker For This Useful Post:
Old 03-13-2023, 03:16 PM
i4abuygto's Avatar
Thanks guys, for your help.
I am not running any emissions either - 403 with better cam - headers - internals unknown but runs strong. Rear end has been upgraded to approx 3:25 gears. I just want to clean up the vacuum system so it is correct for what I have.
I will start another thread in the street engine section.
Thank you.
Old 06-11-2023, 11:20 AM
Alright, I'm finally just about done and ready to put the heater box back in the car (engine took precedence for a bit). Almost everything is solved. One last question, what attaches to this screw?
Old 06-11-2023, 11:33 AM
That wouldn't ground it anywhere, though. That screw just threads into plastic
Old 06-11-2023, 11:34 AM
Might be a wire harness or vacuum line clip... but if it is, I misplaced it
Old 06-11-2023, 12:14 PM
Try this, loop retainer for the vacuum line that goes to kick panel and cowl door. It's just folded over and screwed.
20230612_021013 by Ben, on Flickr
20230612_021613 by Ben, on Flickr
Old 06-11-2023, 12:43 PM
Ah hah! That's the one, thank you!
  #38
Old 06-26-2023, 12:55 PM
i4abuygto's Avatar
I fixed all vacuum issues and installed my heater box and everything seems to work good.
I have new carpet in and the dash and behind dash duct work is ready to be installed. Before I proceed.....
I noticed on the attached photo of the duct schematic that there looks to be a gasket of some sort between the heater box and the cowl evaporator box. There was nothing there when I removed the heater box and is that missing seal necessary?
The box was kind of a bitch to install and the lower nut is hard to get to with headers so I would rather not remove the box again to put in a seal if not necessary.
Please advise.
Thank you.
Name:	duct shematic id.jpg
  #39
Old 06-26-2023, 06:16 PM
That's the firewall seal.
  #40
Old 06-27-2023, 01:27 AM
i4abuygto's Avatar
I am missing something in the description - I did not have this when removing the heater box. Is this a removable seal and is it located on the under hood side of the firewall.
