Old 07-26-2023, 05:00 PM
Default 81 FB condenser in a '74
Would a newer condenser fit/work with a '74? Found a used one for cheap.
I have a newer chinese compressor but maybe the plumbing for the condenser would be different if anything?
Previous owner put a screw thru mine... 🙄
Old 07-26-2023, 05:39 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
You're better off with a parallel-flow condenser if you intend to use R134a. Find a bolt-in kit like this: https://www.originalair.com/72-81-fi...-parallel-flow
Old 07-26-2023, 11:39 PM
hmmm...
He wants next to nothing and that's what i can afford currently.
I'll look into this one if it's nfg.
Thanks!
Old 07-27-2023, 07:07 AM
Trevor78 Trevor78 is offline
'72-81 for BOP engines were the same. Chev engines used different plumbing.
Oh, just saw link saying same. All good. Compare the pipe outlets and angles, there's 2 types as above. I'd imagine a 6-cyl version would also be for chev in a '74. but most are Pontiac back then.
