Old 04-19-2025, 05:58 PM
Stibley's Avatar
Stibley Stibley is offline
Default What thread size are 1957 Pontiac lug nuts
Hi All, I'm in the process of getting some new wheels for my 57 Pontiac and need to know what size and thread type the lug nuts are?
Old 04-20-2025, 02:06 PM
694.1 694.1 is offline
The left side used left hand threads and I use a dab of yellow paint on the lugs to remind me. My thinking is yellow has 2 Ls in it, Yellow=Left.
Helps prevent brain farts!
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 04-20-2025, 04:22 PM
Stibley's Avatar
Originally Posted by 694.1 View Post
1/2-20
Thanks greatly for the quick reply and good call on the left hand nuts. Is the thread type UNF? I'm looking to get some Torq thrust originals as I would like to give my car the look in the picture. As you have a 57 Starchief do you know what the max width and wheel back space I can go to with 15 inch rims. I'm currently thinking 15x7 with 215 70 15 tires would be a safe bet. Maybe 75 profile tires like the ones in the pic.
The Chrome smoothies are my current set
ID:	650557   Click image for larger version
Old 04-22-2025, 12:37 AM
Jack Gifford's Avatar
Jack Gifford Jack Gifford is online now
formerly 'Pontiac Jack'
... The left side used left hand threads...
Are you sure? I no longer have any to look at, but I thought the LH threads were used on the passenger side, which would tend to tighten the lugs as the wheels rotate forward.
Old 04-22-2025, 08:43 AM
From 1961 Service Manual: (can't get to 1957 manual)
Left side has left hand threads
Right side has right hand threads
I'm guessing they mean left side is as sitting in car?
BTW, I think if the direction is determining 'tightness' this would be correct? The thinking could be that the axle rotation against the wheel/road friction would be correct?
Old 04-22-2025, 11:43 AM
Bill Hanlon's Avatar
... unless you drove more in reverse.
The Following User Says Thank You to Bill Hanlon For This Useful Post:
Old 04-22-2025, 06:16 PM
Poncho60 Poncho60 is offline
If the wheel studs on your 57 are original, I believe the drivers side studs should have an "L" stamped on the end of them. Just fyi.
Old 04-22-2025, 06:28 PM
Sillyness.
Maybe a spindle nut but left-hand thread lug nuts?
Old 04-22-2025, 06:58 PM
B man, that was a thing! Pontiac was not alone, not sure when they figured out it was unnecessary-
7th Firebird
57 Starchief
Old 04-22-2025, 07:10 PM
My dad once owned a later 1950s Chrysler New Yorker.
Needed to change a tire and broke off at least two lug studs before figuring out the problem.
Dumb design.
Old 04-22-2025, 10:32 PM
Chevys & Olds used this arrangement as well. Pontiac used this all the way thru 63 including on the 8 lug setups. The concept was not bad. Check out how the true knock off setups were designed. Wheel rotation tightened knock offs, LH & RH.
Old 04-22-2025, 10:47 PM
A wheel rotates directly around a spindle nut or a wheel knock off nut. That rotation can affect those fasteners.
A wheel does not rotate directly around a lug nut or lug bolt, so the wheel simply rotating will not tend to loosen the lug nuts or bolts. Vibration can loosen those fasteners but not the rotation of the wheel itself.
Two completely different things.
My older VWs have a left-hand threaded driver’s side spindle nut. My Pontiacs have right hand threaded spindles on both sides. Both use either cotter pins, lock plates or a clamp nut to secure the nuts. So both ways are fine for that. The rear drums on an old VW are secured with a large nut and cotter pin in the center to a splined axle, both sides are right-hand thread.
Left-hand threaded lug nuts were a stupid idea. Everything that came off of the drawing board was not necessarily good.
Old 04-28-2025, 10:52 AM
peters23 peters23 is offline
Original Pontiac lug nuts and studs should be 1/2-20 (UNF).
You should be able to use Dorman 611-016 studs if you want to change LH to RH.
The Following User Says Thank You to peters23 For This Useful Post:
Thread Tools
Display Modes
