#1001
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
#1002
Been following along. sucks for all those involved, buyer and seller. Anyway, if u wanted to hear what poly locks barely touching a valve cover sounds like, watch this video. This was a month ago for me. I doubt that is your problem as paul has said, but it so easy to pull off a valve cover I might just do it for thoroughness. Maybe the knock sounds different with cover off to help pin point and also watch the valves running.
I added second set of valve cover gaskets and my ticking/knocking was gone. |
#1003
So he actually farmed it out to someone else?
#1004
#1005
64speed,
We're going to address the PCV but as you said, my friends and guys from the forum say that wont cause a knock but it will settle the idle. 68 461 Bird, Paul felt that it wasn't a good idea to send the motor back for something silly. He spoke with everyone that worked on the motor and suggested parts to replace. $1,900 later in diagnosing and parts and an additional $2,575 to Paul, I have the same knocking noise as I did before. Take a look at this picture. Could this knocking noise be heard without mufflers? I would imagine not but I'm still waiting for Paul to post the video of my motor running at idle Last edited by Va68goat; 07-29-2019 at 10:01 PM. |
#1006
MidnightAuto,
Thats close but that was checked here after the knocking noise was discovered. Paul suggested thicker gaskets and thats what I sent him. I'll have to look at some old pictures and videos but I think we tried taller valve covers and the knocking noise was still present. |
#1007
True. Those covers are cast really thick and the inside has a rounded roof with lots of material at the top. Believe the set we measured had a little less than 1-3/4" clearance inside. Ended up with 2 thick gaskets with them on a Kaufman head.
#1008
I read a comment that Paul gave up on the thread because he didn't like the direction it went. You would think he would want to save his reputation and do what it takes to make a customer happy after taking so much money from you. |
#1009
Good, because you obviously can't see the forest for the trees, you'll never figure it out continuing down a path like this.
#1010
Oh if you only knew what's been going on off the forum for the last year and half you would understand Paul's point of view. Unfortunately all that's been shown here is Joe's point of view, dragging Paul through the mud. Paul has held himself to a much higher standard and has already went above and beyond what any other business owner would do in a situation like this. Most would have told Joe to pound salt long before all this. Paul doesn't have to worry, his customer base is doing just fine. Doesn't really matter what Joe thinks or says. He would benefit more proceeding to diagnose what Highway started and stop pointing fingers. But it'll take someone on Joe's side of things to tell him that before he'll comprehend it
#1011
Absolutely, but do you know how infrequently lifter rollers go bad WITHOUT some sort of manufacturer's defect? I've seen 6.9/7.3 IDI diesels with 500,000 miles on them that still had free lifter rollers.
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
#1012
It's not the plumbing; it's the PCV valve itself. If you get a bad one they will sometimes flutter with engine vacuum. The fluttering causes a clicking sound. It's a long shot but worth a look.
#1013
Formulajones,
You're at distraction at best. Just because I don't consider your opinion of value does not mean the knocking will not be located. I'll address this one more time but I would like to get back to topic. As for whats been going outside of the forum, it would be very easy to screenshot everything since the motor failed on the dyno and cut and paste emails. Arizona and Virginia are both one party consent states as well. As soon as the build went bad, I immediatley realized I had to document everything. I actually saved everything since day one but thats just me. Comprehend this Formulajones...why would I do or say anything that would anger Paul when I needed his involvement while we were diagnosing the problem? Why would I do or say anything that would anger Paul while he had possession of my motor? I questioned him like every disappointed customer would. I never said one negative thing about Paul until I paid the $2,575 ransom and I had the motor in my possession. Now that the motor is still knocking and he ran away, anyone would be mad. I don't want to take any action outside of talking to him and having him help me get through it. I'm prepared to take this to another level right now if need be but I don't want to do that because I feel this is best handled man to man. Paul has made a choice to wash his hands. So eventually, there is not going to be another option for me. As I said before, Jeff has been texting me and said he has a guy that can come look at the motor. I appreciate that and I hope that happens soon. I just want this motor right. As I told the guys that have worked on my car. I don't want guys that are "on my side", it's best to have guys that don't even care about that and they just want to see this motor run. Remember Formulajones....you have my number. Feel free to call me but you're not moderating this situation. Last edited by Va68goat; 07-30-2019 at 07:36 AM. |
#1014
Not even a remote possibility. But Thanks
#1015
You would think that be the case. Says something, doesn't it?
#1016
The engine was run with the following removed. All belts, Fuel pump and torque converter completely disconnected. It was sitting there Virgin on the frame without anything attached. Unfortunately it did not make any difference. It has been gone over with a mechanics stethoscope and run with valve covers off. With no change. Every possible test has been done to further evaluate the valve train with no results. The only signature picked up on the stethoscope was at the base of the distributer and the oil filter receiver. In over 30 years of Pontiac engine experience this is the first time I have ever seen something like this that could not be easily identified. |
#1017
I know the distributor has been pulled a few times .... are the ears off the oil pump drive shaft so it could be pulled and checked for witness marks?
#1018
The witness marks were already addressed. The oil pump shaft is the same and is was checked to be straight and undamaged. No the shaft cannot be removed. Please refer to video of shaft turning while in motor. All is as should be. :-)
Treat me Nice. I will treat you Nicer. Treat me Bad I will - - - - still treat you nice- Last edited by Pronto Poncho; 07-30-2019 at 12:22 PM. |
#1019
dataway,
Here are the witness marks that were located on the oil pump shaft. |
#1020
Dataway - ears are intact
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
Closed Thread |
