Old 07-17-2013, 05:57 PM
pressgod1's Avatar
pressgod1 pressgod1 is offline
Default larger alternator
I am going from an 88amp alternator to 140amp...do I need a larger gauge power wire so nothing melts?
1969 Custom"S" 400 stroked to 455 Holley Dominator 870 Pontiac Performer intake KRE heads Kieth Black pistons Crane Cam Hooker ceramic coated headers CVF Racing pulley system 700r4 trans built/700hp Ford 9" 3.73 posi 4-wheel disc brakes
Old 07-17-2013, 06:16 PM
LATECH's Avatar
LATECH LATECH is offline
Yes. And the length matters to. The alternator wont be putting out 140 continuous but it can peak at 140 for a short time, and things could heat up.
Probably should run a 6 gauge , and no longer than around 6 feet. You will also need to increase the main ground wire size to be safe.
