Tri-Power Tech 57-66 Tri-Power Talk
Old 06-06-2013, 11:01 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Thumbs up
It's been 3 years since I started this thread about the "One Year, One Application Only" 66 Tri-Power plastic PCV connector. It seems it has finally gotten the attention it deserves and Ames offers it for the guys that want it factory correct! Their pic looks like it is real close the the OEM design.
Old 06-08-2013, 07:27 AM
chrisp chrisp is offline
Originally Posted by 60sstuff View Post
I found a pic of goatman65 1966 Tri-Power car still wearing it's one year/one model PCV connector.
Also two different test car articles from 66 magazines clearly showing this unique connector!
Picture #2 has a clip for the power bake line that holds it to the intake manifold , any leads / pictures or description of that part avail. ? Not talking about the bracket that is bolted to the intake , the small wrapped offset clip . Also 66 tripower all use a 3/8" fitting for PVC 64/65 used 5/16" .
Old 06-08-2013, 10:44 AM
60sstuff's Avatar
This one that's held in place by the valve cover bolt?
Name:	1966 GTO YR Engine Bay (61).jpg
ID:	325723   Click image for larger version
Name:	1966 GTO YR Engine Bay (64).jpg
ID:	325724   Click image for larger version
Name:	1966 GTO YR Engine Bay (64a).jpg
Old 06-08-2013, 11:02 AM
Ok now i see it is a pinch clamp . Very nice of you to post the pics. Now i can fix mine , thanks again .
Old 06-08-2013, 11:13 AM
60sstuff's Avatar
65 and 66 used this exact set up for power brake equipped cars. Also 67 was the same except the bracket was a different design. I'm not sure how the 64 power brake cars were designed in this area?
Old 06-08-2013, 11:51 AM
For 64 5 6 tri-power were them clamps used on all areas of the power brake line ? I have seen then where the fitting is @ the carb. but unsure @ the end where the hose attaches @ the booster . thank you
Old 06-08-2013, 12:38 PM
60sstuff's Avatar
No clamp was nessesary at the (hose to PB check valve) booster as seen in first pic below.
These OEM pinch clamps were used at other locations such as the CPCV hose to oil fill cap (also seen in first pic below) on 66 models and on vacuum linkage Tri-Power GTO's as in second pic.
The return hose on power steering equipped cars also used the pinch clamps.
Name:	#9784800 NW Hose - Center base to cap (2).jpg
ID:	325733   Click image for larger version
Name:	1966 GTO YR Engine Bay (32).jpg
Old 12-21-2014, 09:10 PM
lugnutx2 lugnutx2 is offline
I have one of those 4 way plastic connectors for a 66 tri power manual with smog and I won't be using it. Also have the smog air cleaner bases. I'll trade for steel 66 non smog tri power air cleaner bases.
Old 12-21-2014, 10:43 PM
60sstuff's Avatar
PM Sent
Old 01-14-2016, 07:47 AM
Have a GM NOS in sealed bag if needed PART # 9784831 GR.1.7.45
Old 01-14-2016, 09:09 AM
Jason67's Avatar
Jason67 Jason67 is offline
Default Tri Power fitting
Chrisp, PM sent.
Jason
Old 01-16-2016, 06:40 PM
Jason67's Avatar
These are also advertised through Inline Tube with correct part # and WMP. Probably the same part as our host.
Jason
