Old 02-27-2007, 11:50 PM
John Milner's Avatar
John Milner John Milner is offline
Default headers
What headers do you guys run on your Venturas? What headers fit fairly good on these cars without having to beat the crap out of them to make them fit?
Old 02-28-2007, 12:17 AM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
I used Heddmans on a customer's 74 GTO that I did the engine on a couple of years ago. They were a short style that fit pretty well. Was on a 4 speed car too and had no problems with the clutch linkage.
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
Old 02-28-2007, 12:31 AM
Were they the shorties? Mine is a 4 speed, so fitting around the clutch linkage is a concern. Thanks
Old 02-28-2007, 12:40 AM
IIRC, yes they were...
Old 02-28-2007, 07:03 AM
Colin's Avatar
Colin Colin is offline
Location: The ObamaNation we once called the United States of America
Mine is a 4 speed and has Hooker Super Comps.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."- General George Patton
"Perpetual peace is a futile dream."-General George Patton
"I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."-Thomas Jefferson
"Any society that would give up a little liberty to gain a little security deserves neither and will loose both."-Benjamin Franklin
Old 02-28-2007, 07:26 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Maddogs - fit near perfect.
Old 02-28-2007, 03:20 PM
74gto's Avatar
74gto 74gto is offline
I got headmans also. Fit great, but I ordered mine for 67-69 Firebird. Forgot the number, 1 3/4 pipe also, never went bigger, but if I do I willhave to clearance pipe a little on drivers' side motor mount (frame portion of car) JOHN
74 GTO 406 T400
74 Firebird 350 4-speed
68 GTO Convertible 400 T400
76 GP LJ 400 4BBL T400
78 Chevy 1/2 Ton Truck
Oh yea I love my wife very much
For some reason it got erased when I put it here last time!!!!!! hmmmmmmmm
Old 02-28-2007, 07:13 PM
nonnova's Avatar
nonnova nonnova is offline
Location: Cleverly Disguised As A Responsible Adult In The Motor City
Mine are Dynomax for the 67-69 Firebird. No clearence problems with the clutch linkage, slight massaging around the steering box.
1974 Oldsmobile Omega: '73 Pontiac YX code 400, 4X-7H Heads, Edelbrock cam/intake,
Holley 750 dbl pumper, Dynomax headers, 2.5" 50 series Flowmasters, M20 Muncie 4spd,
8.5" 10 bolt with Auburn race series posi, 3:73 gears and 4 wheel disc brakes
Looking for the right Ventura for the drivetrain ('73 w/o Sprint nose)
Old 02-28-2007, 11:32 PM
Rob B's Avatar
Rob B Rob B is offline
Hooker Super comps work great with D-port. I have Hedmans with my eheads and had to do some massaging with the drivers side. Was not happy with the fit of the Hedmans.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 02-28-2007, 11:40 PM
ventura7211's Avatar
ventura7211 ventura7211 is offline
All the headers I've ran have been for a first gen application. I started wtih a set of cheap dynomax 1 5/8" d-port, the fit great no hammers needed, the only problem was that the collectors ended at differant points under the car so the driver side exhaust tube was longer.
I replaced those with a set of d-port heddman 1 3/4", I didn't like them as the rode up too close to the floor pan and 2 1/2" exhuast was the largest I could run.
I've been sick with the flu, but once I'm over this I'll be installing a set of hooker 2" round port headers, a couple of the tubes wrap around the subframe, exhuast will be collector mufflers, If I'm not happy with the fit I have everything needed to make a set of 2" to 2 1/8" to 2 1/2" step headers with a 4 inch collector, just really don't want to put in the time right now, already made 3 sets of headers this winter, lol.
Old 03-03-2007, 02:34 PM
greggutknecht greggutknecht is offline
On my 72 i installed a rack&pinion steering and installed 2nd gen 2inch to 3.5 collectors,fit perfect.Never had much luck with factory steering gear in place with correct headers without hammering.Thanks Greg
Old 03-03-2007, 02:53 PM
ponjohn's Avatar
I should clarify as well, I run a rack and pinion.
Old 03-20-2007, 09:35 AM
73sprint's Avatar
73sprint 73sprint is offline
Default headers
Do you have the part number on the shorty headers.
Old 03-24-2007, 10:23 PM
AGTO8U's Avatar
AGTO8U AGTO8U is offline
I have a set of Hooker Competition #4902. Haven't installed them yet on my 73 Ventura, but would like to know if anyone else has installed these in a Ventura. The passenger side #6 tube looks like it might be very close to the firewall/floorboard. My car has factory AC but that will be removed before I put these on.
ID:	86272   Click image for larger version
Old 03-30-2007, 11:17 AM
Rob B's Avatar
I don't remember the part # for the Hooker's I had on my car but they were for a 73-74 Ventura not a 1st gen firebird and they fit great! No tweaking or denting needed at all on them. The only problem is that you have to remove the oil adapter before you can install the header on the pass. side but thats a common thing with any header.
Old 06-24-2007, 08:40 PM
BILTIT's Avatar
BILTIT BILTIT is offline
Hooker comps are 4902, super comps are 4107. Both are for d-ports.
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 06-26-2007, 09:26 AM
73sprint's Avatar
Default headers
I just installed Hooker supercomps on my car.They fit excellent.
Only need to remove the starter to make the fit easier and the oil lifter.
No issues with the clutch linkage.
Only one issue there is one header bolt that is difficult to install on the passengers side center port.You need samll fingers and a crow foot wrench.
Old 06-26-2007, 07:11 PM
BILTIT's Avatar
Does your driver side hang lower than your passenger side? Mine does, only complaint about supercomps.
Name:	Picture 166edited.jpg
Derek B.
Old 07-13-2007, 10:01 AM
73sprint's Avatar
Default Headers
Actually they look pretty good.I was sceptical installing these as I didn't want to have to get the hammer out.I hooked up a set of stainless magnaflows and I had a stainless exhaust built .
Old 07-13-2007, 10:03 PM
AGTO8U's Avatar
Do you have any pictures of the supercomps? I'm wondering about the fit around the steering box and passenger side firewall. I have a set of comps that are smaller dia but not sure if the routing of the tubes is similar. The way things are going it will be awhile before I can install them.
