Old 08-25-2008, 08:32 AM
BILTIT's Avatar
BILTIT BILTIT is offline
Hmm, interesting info on the lash. My card says 26/26 hot and i have it lashed at 18/20 cold. Maybe i will loosen it up to what the card says and see how it feels.
There was also a sasktel camera crew there filming the event so i am going to try and get a copy of it when they air it on tv.
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
  #62
Old 08-26-2008, 01:02 AM
71 Ventura II's Avatar
71 Ventura II 71 Ventura II is offline
Dang man, you really tightened the lash on that puppy! When you open it up to the .026/.026 your going to get more vacuum and stronger lowend power. IMHO This is a major reason the 60' has suffered. Your cam even when lashed properly needs more converter so when you crank the lash real tight like that the issue is compounded further by making the cam run even bigger than designed. At least now you know why the "Upgrade" wasn't working right so it can be fixed. Keep us posted! JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
  #63
Old 08-27-2008, 08:00 PM
BILTIT's Avatar
You may be right. I will be loosening the lash in the next few weeks hopefully (if work and building the new garage does not get in the way). Unfortunatly, i will not be going back to the track this year as i have too much other stuff on the go.
Derek B.
  #64
BILTIT's Avatar
I did notice i was crossing the line at ~5500 rpm this year compared to 5200 last year.
Derek B.
  #65
Old 08-28-2008, 12:19 PM
BILTIT's Avatar
Well, i checked the schedule and i may be going back to the track oct 4&5 if there is no snow on the ground. I will loosen the lash and may have the nitrous online for that weekend!
Maybe i will get back in the 11's on motor and one shot at in the tens on the juice.
Derek B.
  #66
Old 08-29-2008, 12:59 AM
Tire height can play a big role in topend rpm as well as 60' times, bias vs radial tire, and rear gears. If/when you go back to the track I'd like to see the car run with the stickiest & shortest set of tires you own NA; while moving the shift point up. Based on the topend mph and rpm of the NA run may require a taller set of tires with the nitrous to help out with the topend rpm from the increased mph. Good luck I'll be watching! JD
  #67
Old 08-29-2008, 11:06 AM
BILTIT's Avatar
Shortest and stickiest i have are the 275/60 MTDR's, same as i ran last year. The only difference from last year is the cam and intake. I am running consistent MPH of 110-111, last year i was around 108-111. I will move the shift up and see how it goes, say 6300?
Derek B.
  #68
Old 08-29-2008, 04:10 PM
I was going to say do a baseline run shifting at 6000 then follow it up shifting at 6200 to see if the MPH picks up. Johnny G. use to shift his 290-b cammed 462 engine around 6500-6800 in a 3700lb 69 GTO and ran 11.0's. I'd say slowly work your way up to 6500 using the MPH as a guide whether the engine likes it or not. It may like a little more or a little less than 6500 only testing will say. Honestly, I feel your combo should MPH 115+ so let it breath and see what it says!
NOTE: Make sure you have enough "Jet" in the carb as more airflow means more fuel consumption. JD
  #69
Old 08-29-2008, 09:12 PM
BILTIT's Avatar
K, will do. Carb is jetted 80/88 right now with rear PV plugged. It is rich as the tailpipes are pure soot.
I may purchase a A/F data logger by that weekend though, would help with the tuning.
Derek B.
  #70
Old 09-06-2008, 09:52 PM
BILTIT's Avatar
The local photogragher got the preview pics up, i will be buying some.
ID:	142256   Click image for larger version
ID:	142257   Click image for larger version
ID:	142258   Click image for larger version
ID:	142259   Click image for larger version
Derek B.
  #71
BILTIT's Avatar
One more.
Derek B.
  #72
Old 09-08-2008, 08:09 PM
BILTIT's Avatar
Just ordered a A/F ratio monitor and datalogger. Hope to have it on for the oct 4 races.
http://www.zeitronix.com/Products/zt2/zt2.htm
Derek B.
  #73
Old 09-08-2008, 08:21 PM
ponjohn's Avatar
ponjohn ponjohn is offline
coool!!!, do you have bungs for the O2 sensors?
I am going to put them in and have the headers coated over the winter.
  #74
Old 09-08-2008, 08:23 PM
BILTIT's Avatar
Yup, i have dual naroow band sensors in now but do not trust them enough to tune with.
I run my sensors just after the header collector.
Name:	Picture 166edited.jpg
Derek B.
  #75
Old 09-09-2008, 05:56 PM
BILTIT's Avatar
My SL eliminations run, was very close!
My friends are terrible videographers!!
http://www.youtube.com/watch?v=86kGqHD8uh4
Derek B.
  #76
Old 09-09-2008, 06:44 PM
ponjohn's Avatar
Thanks for the picture, thought they had to go into the collector.
  #77
Old 09-09-2008, 07:37 PM
BILTIT's Avatar
I think narrow bands are supposed to go in the header as they need to be a certain temp to read well. Widebands are heated so they can be further away and still work.
Derek B.
  #78
Old 09-15-2008, 11:08 AM
BILTIT's Avatar
Originally Posted by a95toy View Post
Builtit,
Yours is back from the body shop and mine just went in. They will start on it this Monday and i'm excited to get it back. The only thing i'm afraid of is the 8.5 rear not holding up so i'll probably be in a market for a 12 bolt for it later. Stepped up the ring gear and i wanted to get yours and others opinion on a tranny.
It has a muncie m21 in her now but thinking of going to a 5 or 6 speed down the road. Any suggestions. I'm getting a few opinions locally everyone so far are talking about the TKO 600. Send some pics
later
Toy
I don't think the 12bolt is an upgrade over the 8.5'' 10b. What i have seen is that the 12 may be ''alittle bit'' stronger but the 10b parts are easier/cheaper to find (80's chev trucks, thousands out there). If i were to upgrade from the 10b i would go ford 9'' or dana 60.
I dont think i will be upgrading mine until i go twin turbo, which will be a year or two.
I have had no problems yet. I plan on upgrading the heads in spring (315cfm KRE-D's by SD) and restalling the 'verter higher so i will see how it handles it next year.
Derek B.
  #79
Old 09-16-2008, 06:10 PM
As long as it's the 8.5 10 bolt and not the weaker 8.2 you should be fine. As mentioned the parts are much easier and cheaper to build the 8.5 10 bolts. I found the 9" ford rearend from a mid-70's Granada is overall 1 1/2" shorter than the 8.2 rear I removed. So being 3/4" shorter per side did cause tire to body interference necessitating a mini-tub. Once I relocate or remove the factory leaf springs I can run a section width close to 13.5-14.0" depending on the rim back spacing. Just trying to throw out economical rearend options! JD
  #80
Old 09-18-2008, 12:19 PM
BILTIT's Avatar
Woohoo! Wooped a mopar last night with 500 cubes (twice)!
Then i proceeded to woop a new stage 3 shelby GT500 (twice), haha!
My little street car is doing well so far, now if only i could get alittle faster at the track.
Derek B.
