Old 01-13-2024, 09:52 PM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
Default Want to see how oil flows at -40?
Rich put bottles of Mobil 1 20w-50 and 5w0-30 outside for a few hours. The results I'd say are are expected. Even the 5w-30 thicken ups quite a bit, but 20w-50 is practically cold honey!
https://youtu.be/B-sPl_zpAtQ?si=HvGsO6JsnuOYKSyd
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
The Following 2 Users Say Thank You to TheSilverBuick For This Useful Post:
Old 01-14-2024, 01:16 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Can you imagine what it was like prior to multi-viscosity oil? That's the main reason Pontiac initially used reverse-flow cooling in their V8- to allow transfer of heat from the cylinder heads to the cold bottom end.
The Following 3 Users Say Thank You to Jack Gifford For This Useful Post:
Old 01-14-2024, 12:14 PM
mgarblik mgarblik is offline
Also why 0W-6, 0W-10 and 20 are pretty much standard issue now on modern gas engines. The tiny orifices oil has to travel through for chain tensioners, variable valve timing features and cylinder de-activation systems would never work in cold climate conditions. Running one of these new engines with 10W-30 oil or heavier will almost guarantee a check engine light and dozens of trouble codes. Most of those internal passages are .007"-.015" diameter.
The Following 2 Users Say Thank You to mgarblik For This Useful Post:
Old 01-15-2024, 09:27 AM
Yep, Red Deer, Alberta. Halfway between Edmonton to the north, and Calgary to the south. When I lived there, it went down to -40 regularly, and no one even mentioned it. By the way, -40 is where Celcius and Fahrenheit meet.
