Old 08-14-2012, 10:25 AM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Originally Posted by Steve Barcak View Post
If the car appears to not have been midified much, you can also check the front sway bar. GTOs came standard with a 1 1/8" front and the lemans did not unless it was ordered with it ( not common ).
So, if you see a smaller than 1 1/8" sway bar on the front, it is not likely a GTO as it is doubtful someone would install a smaller sway bar.
A "T" engine coded 72 Lemans is fairly uncommon, most were 350s.
Good info, Steve.
Also, the GTO came standard with a 7/8" rear sway bar, and a LeMans would come without a rear bar - unless special ordered with it - VERY uncommon.
Regards,
"455HO" Lloyd
