Old 06-14-2020, 12:34 AM
Jack P. Jack P. is offline
Default Bench Testing a Dash Tach
Is their a simple way to test a tachometer on the work bench? I have an original 65 dash tach I want to test, Thanks.
Old 06-14-2020, 04:33 AM
Scott Thelander's Avatar
Mr Serio may be able to help you on testing it....
alot of them work but are poor at calibrating and showing correct rpm
I just hook mine up with a known good SUN tach I have and rev up the old 350 chebby and watch em both
Scott ... my junk only revs to 4200
Old 06-18-2020, 05:24 PM
70GS455 70GS455 is offline
No, not unless you have a function generator, set on square wave with the right duty cycle, like this:
Sent from my SM-T817V using Tapatalk
Old 06-19-2020, 05:03 AM
Geoff Geoff is offline
You can partially test it on the bench, which may be good enough for your purposes, if you have a drill that the speed is known. It helps if you have a spare points dist, not necessarily a Pontiac. I remove the dist gear, leaving just the 1/2" shaft. I fit a short piece of 1/2" rod into the chuck. You can also use a 1/2"drill bit. I use some 1/2" hose as a flexible drive to drive the dist shaft. Hook up the tach & spin the dist. Tach should register double the speed of the drill.
Old 06-22-2020, 09:14 AM
Ben M.'s Avatar
Ben M. Ben M. is offline
Exactly. You can likely even build it and put it in a little box that has a knob to set the output to different RPM values. It's a minor amount of electrical circuits to do it that you used to be able to get at Radio Shack.
Old 06-22-2020, 01:50 PM
Interesting....I thought that I may have had an old Function Generator...but all I found in my old '80s stuff was an BK RF generator and an old scope. I could have sworn that I had a BK generator around. I would love to see a schematic for the hook up?..Just in case I can find it.. I have a serious 'can't see the forest for the trees' situation around here.
Old 06-22-2020, 05:48 PM
Much like the box in my picture
Old 06-23-2020, 09:23 AM
Ben M.'s Avatar
Exactly. Something like a 741 or a 7414 with a mechanical knob to adjust the resistor could probably be built for less than $15 and make it look nice. It doesn't need ridiculously fast or ns-sharp edges.
Old 06-24-2020, 05:38 PM
I use the LM3524
