Old 03-09-2021, 01:24 AM
Goated66 Goated66 is offline
Default Running 1975 engine, 4x heads, 7040263 carb, 068 cam, 9799068
Clearing out a few parts...
1.) Running 1975 Pontiac 400 ‘ZT’ (185 hp) - $1000
2.) Heads 1973/74 4X Big Valve G203 (July 20,1973) / H243 (Aug 24, 1973)
- Motor is currently running well, doesn't smoke and has good compression. Happy to send a video. Also willing to sell the short block and heads separately if desired. No ancillaries included. Longblock or shortblock only minus the oil pan.
3.) Carburetor 7040263 VA (Feb, 70) / currently installed on above engine / operating properly and appears to be all original / good driver carb - $400
4.) Factory Ram Air III 068 Cam, Lifters, pushrods / used / good condition - $125
5.) Ram Air III intake manifold / 9799068 (Mar, 70) / no cracks / surface rust - $175
6.) Pontiac 400 Nodular Crank (9)773524 'N' / 1968 / surface rust only / needs to be cleaned up - $100
Located in San Francisco, CA
Old 03-10-2021, 12:32 AM
PepinoBBB PepinoBBB is offline
hi what will be the price for the heads. Thank you
