Old 02-28-2024, 09:12 AM
LET LET is offline
Default Dome light
67 GTO the dome light will not turn off. So far I have removed both door, jam, switches, checked all the white wires for grounding issues. The headlight switch is new it is turned clockwise which dim the dash lights. If you turn it counterclockwise I can feel it when it’s supposed to turn on the dome light. Do not understand why it will not go off any help would be appreciated.
Old 02-28-2024, 10:19 AM
george kujanski's Avatar
The white wire in the circuit is being grounded somewhere.
George
The Following User Says Thank You to george kujanski For This Useful Post:
Old 02-28-2024, 12:43 PM
4dblnkldude's Avatar
You might have a screw going through the wire. or touching it.
The Following User Says Thank You to 4dblnkldude For This Useful Post:
Old 02-28-2024, 01:29 PM
To further clarify, consider that the dome light lead has a constant voltage on it. It's just looking for a ground to turn on. That's all the door switches do.
Old 02-28-2024, 01:34 PM
OG68 OG68 is offline
Check behind the dome light for a grounded white wire
2007 Cadillac SRX
Old 02-28-2024, 05:12 PM
If all else fails , plug the old HL switch in just loose under the dash and see how the dome operates.
Old 02-28-2024, 09:48 PM
LET LET is offline
Default HL wire underdash
Thanks for all your help guys. I have moved every white wire I can find, and the light stays on.
I do not understand what is meant HL switch under the dash.
LET
Old 02-28-2024, 10:04 PM
If you have your old Head Light switch.
Just unplug the receptacle from the new Head Light switch.
Hold the old one in your hand , and plug the receptacle into it.
See what it does concerning the dome light.
aka the new HL switch might be defective
Old 02-28-2024, 11:02 PM
LET LET is offline
Default HL Switch
I guess I'm showing my stupidity by not knowing what you meant by old HL switch! I will try that, i hope i didn't throw it away!
Old 02-29-2024, 01:11 AM
Never throw anything away.... just don't.
The Following 2 Users Say Thank You to Greg Reid For This Useful Post:
Old 02-29-2024, 09:41 AM
LET LET is offline
Too late, I must have thrown it away, I can’t find it. I must’ve kept that thing for a month.
Old 02-29-2024, 10:37 AM
Cammer-6 Cammer-6 is offline
never need anything until the day after you throw it away :^)
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 02-29-2024, 01:59 PM
6d7gto 6d7gto is offline
What Greg said. We've all done it and probably won't be the last time we toss insignificant parts away...until we need them...significantly!
Old 02-29-2024, 02:29 PM
Sloan66's Avatar
Sloan66 Sloan66 is offline
I had same problem, ended up replacing he door switches and fixed my problem
Old 02-29-2024, 04:39 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
I had the exact opposite problem.
In my ‘65 GTO when opening “only” the RH door the dome / console light would not come on.
I fussed with this issue for days until I realized the door jam switch was faulty.
When I pressed or wiggled that RH switch the lights would come on. When I let go of the switch the lights go off.
Some internal issue with just that RH switch.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
Old 03-01-2024, 05:37 PM
LET LET is offline
Well the dome light now works like it was designed to! I don't know why, but it does!
The Following User Says Thank You to LET For This Useful Post:
Old 03-01-2024, 06:43 PM
Congrats
You fixed it after all .
Old 03-01-2024, 06:46 PM
Don't be surprised if it gives you a second chance...lol
Old 03-01-2024, 10:47 PM
LET LET is offline
No kidding!! I kind of expect that!
Old 03-14-2024, 04:26 PM
LET LET is offline
Default Dome light crazy
Ok, my dome light staying on issue is back! I think i found the culprit, the under dash courtesy light. I took the socket of of the housing and the dome light works as it supposed to, put the bulb back in and the dome light stays off. The courtesy light never comes on. What could be wrong with the courtesy socket????
