Whats that part on the compressor...
...that is cylinder in shape, is about as long as, and is aluminum in color, and has plumbing in and out of it.
More unknowledgeable questions to follow. Bill |
Bill,what kind of compressor. Air compressor ? AC compressor ???
If AC compressor it's probably the filter/dryer.....accumulator.
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
you are referring to the muffler in the AC compressor hose assembly.
I want to buy a new compressor from Ames, it is compatable for the 134 refridgerant, but the muffler is not available. Can I use my existing muffler on the new compressor and the 134? Thanks in advance! Bill |
Yes. The muffler is pretty much just a can with some baffles in it, kinda like some exhaust mufflers. You can re-use it.
just make sure you get purged/cleaned of all traces of r-12 and the associated refrigerant oil.
unless something has changed, r-12 and r-134 compressor oils are NOT compatable.
costs too much |
the oil in the conversion kits can be mixed with R-12 mineral oil and not be a problem. just try blowing out as much old oil as possible and any parts you replace use the 134 oil in the correct amounts.
