radiator for 455
I'm planning to replace the 326 engine in my 67 Lemans with a 72 455. I'm assuming my 40 year old radiator will not be up to the task. What would be an appropriate replacement? Thnx
Brewski,
Give us some more info on the 455. Is it going to be built up for cruising, street/strip or all out? Ive heard and read that 455's tend to run hotter than the other sizes. -Don
1966 GTO 1966 421-9.3-1 comp-Race Tec 23cc Pistons 1966 Tri-Power 1967 670 Heads Pontiac "Highlift" TriPower Cam by SpeedPro DUR 214 Int 224 Exh @.050 - 107 ICL LIFT .445" Int .465" Exh Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers 1966 Muncie Wide Ratio 4-Speed 1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears |
JS, Thanks. Are these available with transmission line cooling for my automatic?
SD, The 455 has just been rebuilt to stock specs, .30 over. The heads were swapped from 114cc to 96cc chambers for a cr of around 9 and a half. The cam is mild and the rockers are stock at 1.5. Not built up, just a strong stock 455. This is intended as a daily driver.
I used a Be Cool aluminum radiator in mine. A direct bolt in. Also make sure you use a fan shroud.
To get the tranny cooler line fittings in the rad, you'll have to buy one of the "direct fit units" either from Griffin, Rodney Rad, Be cool, etc, or you can run a universal fit model like mentioned in a previous post and run a "external" seperate tranny cooler. just depends on what your budget is.
Modine
Different car, but my 4 core Modine radiator is keeping up with my 461,, so far.
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ([_|_] ##\|/##[_|_]) |
Do you have a 4 row radiator now? If you do it may be fine for the job.
1968 Midnight Blue Firebird coupe. 428 with Butler E heads. 4 speed/3.23 posi. Rick |
just remember it's not always about the size of the radiator
its about air flow and approriate circulation too guess you can say to make sure all pieces to the puzzle are there and functioning correctly |
If you want to spend the money a new radiator is a great investment, if you are on a budget, let us know if you have a 2 core or a three core. I had a great stock three core in my 67 Tempest which I used when I swapped out my 326 for my worked 462. I was running about 220 degrees, realizing this was too hot, I put in not one, but two bottles of Water Wetter
http://www.redlineoil.com/products_coolant.asp and never ran above 190 all Summer long, never had a problem.
Ant 1967 Pontiac Tempest, GTO-Inspired "What's so special about having Italian food cooked by a bunch of friggin Mexicans" Paulie- Rocky Balboa "Your heart is free, have the courage to follow it" Braveheart http://i106.photobucket.com/albums/m...Wm0SlqN030.jpg |
