Old 08-19-2019, 04:33 PM
Skip Fix Skip Fix is online now
Originally Posted by 242177P View Post
How much And it would have to have header side pipes like that too!
I also forgot to add getting a World Products or Bob Walla's aluminum 409 block with Carl McQuillen's Z-12(updated factory Z-11_ heads for the 64 Impala project.
https://www.mcquilleneng.com/
  #42
Old 08-20-2019, 02:00 AM
64speed's Avatar
64speed 64speed is offline
I’d also get a 57 stainless steel roofed Cadillac and make my wife drive me around int it LOL JK
  #43
Old 08-20-2019, 01:08 PM
ta man ta man is offline
Originally Posted by ta man View Post
I would buy my local dragstrip before it eventually shuts down and build a shop and a house there and keep on working on my car but make it look stock appearing.
I'd like to add to this......The first thing I would do is buy Va68goat a new engine.
  #44
Old 08-22-2019, 12:41 PM
Buford T. JuSStice's Avatar
Buford T. JuSStice Buford T. JuSStice is offline
Send a message via AIM to Buford T. JuSStice
It's WAY too early to be hopping on the GDI wagon. Eco-boost had direct injection, it now has dual injection. Christian von Koenigsegg mentions port vs direct in the Freevalve video.
https://youtu.be/S3cFfM3r510
And as long as we're talking lottery money, you gotta start with an aluminum block.
Yeah, true. Aluminum block SHOULD have been on there, but I'm still thinking like I'm poor... already got the Iron block, might as well use it, right? lol
But yeah, I'll have to watch that video from Koenigsegg later, but I do know GDI has some significant advantages over port injection. For one, since the fuel is atomized far better with direct injection, it's possible to utilize higher compression ratios much more safely. For example, a car with GDI can push the envelope on Compression Ratio up to 14:1 on pump gas while most other fuel delivery methods can't hack it past 11:1 before needing very high octane race fuel. It basically allows you to push higher compression ratios with pump gas level octane ratings more reliably. You can also go with say 10.5:1 compression and run 89 octane instead of say... 93.
1995 Chevrolet Caprice 9C1 - Daily Driver
1980 Buick Century - WIP: Project Dark Horse
1984 Pontiac TRANS AM - WIP: Project War Chief
  #45
Old 08-23-2019, 01:26 PM
carbking's Avatar
carbking carbking is offline
Two different:
Pontiac:
1962 Tempest, add a 215 CID aluminum V-8 from a Buick, add a turbocharger from an Oldsmobile Jetfire, remove the "Rocket" decal from the air cleaner, print a "Tempest Twister" decal with a drawing of a tornado for the air cleaner, install reworked instruments from the Jetfire with Pontiac dials. Take it to the Pontiac Nationals with hood open, hide a tape recorder or maybe a digital camera somewhere under the hood, and walk away
Non-Pontiac:
Find the nicest 1961 Jaguar XK-E coupe white w/blue interior I could find, and buy it.
Jon.
  #46
Old 08-26-2019, 12:32 PM
wh33lman's Avatar
wh33lman wh33lman is offline
Exactly my thoughts...buy Cayuga, then fix the bumps, build some proper facilities, food concessions, some rentable garage space etc
One of those big modern trailers and motorhomes would be nice.
