Curious on cubes
What has been the largest cubic inches ever built out of a Pontiac both stock block and aftermarket?
Gent is Alaska was running over 600 cu3. Forgot his forum handle.
79 Trans Am WS6 71 Formula 72 Formula 71 Firebird 69 Firebird |
Some info. here; https://www.hotrod.com/articles/hppp...kit-schooling/
Steve B. used a 1959 389 block to get to 577 cubes; deck raised two inches.
*Novel six bolt main girdle and best of all, topped with M/T hemi heads.
Didn't Lynn build a 612 ci engine for JC?
Stan
How many cubes are in the Boss Bird? |
Bill Creech I think was his name. Used to post on here often. 606 in a 64 GTO IIRC. Tall deck
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week ‘14, ‘15, ‘17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
On mine I ended up going with MR-1 block, Ohio crank 4.75 getting 571 cu. pump gas motor |
Damn! What block?
Similar topic here: http://forums.maxperformanceinc.com/...33#post5161433
GTO Jones, glad you came in to this. Your build was interesting.
Boss Bird is relatively small for this conversation. 482 CU IN. 4.25" x 4.25"
Now that run in the 5's at 250 really hits home. Hats off to you guys. |
wdcreech was the screen name I believe
72 Luxury Lemans nicely optioned |
WDCreech profile
WDCreech
64 tube chassis GTO, 606" Indian Adventures tall deck 8.2550@164.17-1/4 1.1981-60' 3.4170-330' 5.2920@132.01-660' ALL Motor http://www.youtube.com/watch?v=gr91bkO7bjM .
Posted this afternoon.
Stan Digitizing Cylinder Heads Help http://classracer.com/classforum/showthread.php?t=73754 Our people say they can get to 99% accuracy from a port, however, when going to the seat area, there are metrics like "picking the throat size." In this case we chose to go 92% that reduced flow quite significantly, so be very careful. We are doing a 642 cubic inch Pontiac engine and the throat size is the limiting factor. We brought the flow back with a carefully constructed intake manifold runner by Mr RPM himself, "the Kat" Rick Katterjohn. Lynn McCarty www.ramairv.com 317.260.3486
If your ultimate goal is power and your not restricted by rules then it's far and away cheaper with less headaches to pump a good amount of boost into a smaller motor.
Well, I'm old school and live by, "there's no replacement for displacement" but my main reason for this thread was to see just how many someone got out of a Pontiac and my basis for that was how many people are getting out of the BBC. I realize that they are 2 different animals but with a BBC being a 454 and a Pontiac a 455 sparked my curiosity.
