Old 08-09-2019, 01:18 AM
Probird's Avatar
Probird Probird is offline
Unhappy Engine autopsy pics for OGR
The first pass Friday at Norwalk I broke the #3 rod in my IA2 engine. It has aluminum rods. It looks like one of the rod bolts broke. Roughly 200 passes on the rods and maybe 4 torque cycles on the bolts. One was broke and the other looked like the threads were pulled out of the rod. The bolt that pulled the threads out was still in the cap when I found it so I’m thinking the other bolt broke first. What was left of the bearings didn’t look to have had any oil starvation. Luckily the crank and block all survived just fine. It’s a Bryant billet crank. Unfortunately as the rod made its way to the oil pan sump it got hit by all the rest of the rods from the #3 on back. One thing I found odd was there were two spiral locks in the pan too. I’ve only removed the pan so I can’t verify where they came from but I’d bet from the #3 piston. I hadn’t had the locks out since I put them on beginning of last season 200 passes ago. Here are some pics of the damage.
ID:	517296   Click image for larger version
ID:	517297   Click image for larger version
ID:	517298   Click image for larger version
ID:	517299   Click image for larger version
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
Old 08-09-2019, 01:22 AM
Probird's Avatar
A few more
ID:	517301   Click image for larger version
ID:	517302   Click image for larger version
ID:	517303   Click image for larger version
Old 08-09-2019, 06:51 AM
slowbird's Avatar
slowbird slowbird is offline
Wow, what brand rod? That's why i like alum rods, break one and engine is still useable, break a steel rod and everything is toast.
Am i wrong or have you and Norwalk not gotten along of the years as far as issues go?
Old 08-09-2019, 08:47 AM
IMO 200 runs on aluminum rods is too many without disassembly and inspection.
Old 08-09-2019, 09:25 AM
GTOGEORGE's Avatar
I had around 150 on mine sent them in to GRP and they were still good, they sent them back.
GTO George
Old 08-09-2019, 09:48 AM
68hotbird 68hotbird is offline
Rick great photos of the damage. sorry you had a failure but glad your block and crank are ok. That rod cap with the broken bolt is very interesting. In the picture from the color of the break and the size of the tensile hinge Id say that bolt has had a crack in it for awhile and it finally let go. hope you get her back together soon.
Old 08-09-2019, 11:42 AM
Old Goat Racer's Avatar
Thanks. You'll be back up and running better than ever !!
OGR
Everybody knows somthin.
Nobody knows everything !
Old 08-09-2019, 01:11 PM
johnta1 johnta1 is online now
Well, it looks like the rod bolts should have been changed at 199 passes?
Really, probably the bolts should be changed every other time unbolted?
Hopefully will have it together and even better and faster.
Old 08-10-2019, 10:04 AM
charlie66's Avatar
Sorry you lost out on racing your car . I was wondering what hapened to you . I always like watch your car go down the track .
My Half AN Injun.....
Old 08-10-2019, 06:45 PM
mgarblik mgarblik is offline
I don't know whose connecting rods those are or who made the fasteners. However, we have been using BME aluminum rods for decades, and have become friends with Mr. Miller. He makes a really big deal out of assembly techniques and procedures. Some of them are quite different from what I was used to, but I followed them because I figured he should know. One was to use no assembly lube on the bolts! He wants the fasteners, the washers, both sides, and the serrations coated with the same engine oil your going to run. He wants the fasteners snugged up only! Around 10 ft. lbs. Then he wants the final torque pulled in ONE step slowly and smoothly to specs. Not in multiple steps like a head stud. Not saying in anyway a failure to do these things caused your rod failure. If the company who made those rods is a major supplier, they should have a metallurgy department. Call them and see if they can analyze your failed parts and you will know for sure. Glad you had only minor other damage.
Old 08-11-2019, 08:59 AM
BADDTA's Avatar
BADDTA BADDTA is offline
Hey Rick
Sorry to hear that bud. That sucks especially at Norwalk. Looking on the bright side though, it gave everyone else a chance to win something for once!! LMAO.
I’m just kidding bro.
Brian
Boobs & bacon
Old 08-11-2019, 11:15 AM
Probird's Avatar
These are GRP rodents with ARP 2000 bolts. I’ve had a few issues at Norwalk over the years. First time ever there, 20 years ago, I caught the car on fire, I’ve had a carb part go down the carb and into a cylinder and had to pull a head off, and a couple other little things. Mostly I seem to break it the weekend before we leave and have to thrash on it to make it.
Old 08-11-2019, 11:21 AM
Probird's Avatar
200??? I actually had them apart and put it back together about 30 passes before this happened. Don’t tell my aluminum rods in my little motor that. They probably have 700 passes on them. Lol! I usually get around 4 to 500 before I start getting worried about them.
Old 08-11-2019, 11:27 AM
Probird's Avatar
That’s the same procedure GRP recommends too. New rods and probably a new piston and
We should be back in business.
Old 08-11-2019, 11:40 AM
But
I did see your car up in the air all weekend and thought it was "just" a tranny problem. This issue does suck much worse though.
Old 08-11-2019, 11:51 AM
242177P's Avatar
242177P 242177P is offline
But
Different motor.
