Old 08-23-2019, 08:20 PM
prostreet64's Avatar
prostreet64 prostreet64 is offline
Default head gasket re-torque
Just got the 403 back together with new Cometic head gaskets. Plan to fire it up tomorrow to make sure everything is okay. What do you guys recommend as far as when to re-torque? A certain # of heat cycles or miles or 1/4 passes?
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet.
Old 08-23-2019, 09:14 PM
Kevspontiacs@aol.com's Avatar
Kevspontiacs@aol.com Kevspontiacs@aol.com is offline
I was always been told after the first heat cycle
Old 08-24-2019, 05:33 AM
taff2's Avatar
taff2 taff2 is offline
I can't say what others do but I re-torque next day after the first warm up, then after the first meeting,then a couple of times per season. Loosen and re-torque one nut at a time following the factory tightening pattern.
Old 08-24-2019, 10:07 AM
GTOGEORGE's Avatar
.........then lithe next day loosen studs/bolts an 1/8 turn then retorque one at a time, this is the proper way!
GTO George
Old 08-24-2019, 03:14 PM
Thanks guys, I should be ready to get that done tomorrow.
Old 08-24-2019, 03:37 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Cometic doesn't recommend re-torquing their head gaskets. If your 403 build is using and OEM Olds block hopefully you switched to head studs...if so I'd run the engine several heat cycles and then re-torque. If your using head bolts I wouldn't re-torque them.
Go fast, see Elvis!
Old 08-25-2019, 07:21 AM
Paul, thanks for the input. I have gotten differing opinions on this subject; some say retorque even with the Cometics and as you say it is not recommended by Cometic. I thought about switching to studs but decided at my power level it was not needed. The old set of Cometics lasted 7 years and probably would have lasted longer if there hadn't been an issue with the heads. My machinist had to take .006 off the face because they were high in the middle. The fire ring on these Olds heads is really narrow and especially after the .024 overbore. There is no margin for error.
