Old 01-21-2020, 11:04 AM
MyBlueToys MyBlueToys is offline
Default 70 g/p headlight parts
In need of headlight springs and inner cups,and marker light screws.
Old 01-21-2020, 11:29 AM
The "cups" are called mounting rings. How many do you need and what position do they fit on the car? I may have NOS ones but quite often on Pontiacs, every one could be different.
Old 01-21-2020, 12:36 PM
Scott Thelander's Avatar
I will check today
I should have everything
Scott
Old 01-21-2020, 06:15 PM
Default Scott ---headlights
The little cups behind the headlight valance that the headlight spring hooks to
Old 01-21-2020, 09:20 PM
Default Hello
here is what I have for headlight parts from a 69 GP SJ
I parted years back.. the buckets have junk bulbs I use for "clocking"
the hi or hi/lo bulbs in the respected headlight bucket ,,,
as mentioned earlier there are differences in rings and buckets and the
corner the spring latches into ...
Scott
ID:	529376   Click image for larger version
ID:	529377   Click image for larger version
ID:	529378   Click image for larger version
Old 01-24-2020, 12:48 AM
Default shipped
2 springs
2 spring cups attached
and
2 long screws
Scott
Old 01-24-2020, 09:26 PM
Default $$$$$$$$$$$$
ON the way
Old 01-24-2020, 10:22 PM
Default ...
....thanks back
