Old 08-15-2011, 07:08 AM
bulletpruf's Avatar
bulletpruf bulletpruf is offline
Default Speedo Gear Adapter 70 4.33
Fellas -
Trans is coming together for my RAIV M21 4.33 car. Trans guy is trying to source the correct parts. Looks like I need a 20 tooth driven and a 6 tooth drive gear - http://www.teufert.net/speedo/70-gto-4.html.
Also need a speedometer gear adapter, which is a new one for me. Not finding much with a search. Are these reproduced or am I looking for a used or NOS one? If I need used, I hope they're not specific to 70 4.33 cars, or I could be looking for a while.
Thanks,
Scott
Please check out my YouTube channel for vintage/classic car and truck builds and shenanigans! https://www.youtube.com/watch?v=jq61KxKp1Is&t=14s
Old 08-15-2011, 11:15 AM
67drake's Avatar
67drake 67drake is offline
I just switched from my original 3.23's to an 8.5 with 3.90's. I picked this up-
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_500wt_1182
It has not even come yet,so I have no idea of quality. I just started a thread in the street section last week about these (New to me also)- http://forums.maxperformanceinc.com/...ht=speedometer
If you search flea-Bay there are some out there.
13.95 @ 102.1 on street tires @ 4055lbs.
Old 08-18-2011, 08:53 PM
bulletpruf's Avatar
Ok, looks like these are not that expensive, but not sure how correct it is. Does anyone have an original one of these that they can take a picture of?
Thanks,
Scott
Old 08-18-2011, 09:53 PM
67drake's Avatar
I'm kind of surprised by the lack of info on these. Not too much response in my linked thread,as you can see.
In my case I was not too worried about correct,just accurate. I'd be interested to see what originals look like myself.
FWIW,I did put my adaptor in yesterday,but no time to drive it yet.
Old 08-19-2011, 01:29 AM
PMDRACER's Avatar
PMDRACER PMDRACER is offline
Click the link, save the file to your desktop by going to File - Save As, click Cancel to the login prompt. Open it up and insert your info on the left to find your needed drive/driven gear.
GM part numbers included. You can still order most if not all the parts listed last time I checked.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.
-RONALD REAGAN
462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg
Old 08-19-2011, 07:51 PM
My442 My442 is offline
Here is a GM speedo adapter.
Hard to find.
Name:	Speedometer Reducer.jpg
Old 08-19-2011, 08:13 PM
Ram4king's Avatar
Ram4king Ram4king is offline
Ive seen them on the automatics but have never seen on on a 4speed car. I see them more on the chevies.
Old 08-20-2011, 10:06 AM
bulletpruf's Avatar
Hard to find.
Appreciate you posting the picture. Do you know what the part number is? Also, what was it originally installed on?
Scott
Old 08-20-2011, 10:44 AM
bulletpruf's Avatar
Found the correct pages from the assembly manual, but very difficult to read. Pages are 12-4.1 thru 12-4.4. Looks like the adapter part numbers are 540474, 535615, and 535617. They are similar in appearance to the one pictured below. Any ideas on which adapter is which? Wonder if they all look the same externally.
Scott
Old 08-20-2011, 11:02 AM
bulletpruf's Avatar
Scott
Anyone have a 70 Assembly Manual that doesn't have lousy print quality on these pages?
Scott
Old 08-20-2011, 11:10 AM
bulletpruf's Avatar
Now I'm not sure that I need an adapter - see page 15 here: http://www.murraysimon.com/GR04_ILL.pdf
No adapter listed for 4 speed, G70 14 tires, 4.33 gear.
Scott
Old 08-20-2011, 04:40 PM
PMDRACER's Avatar
Scott, no offense man, but you just aren't reading the posts are you? If you would have paid attention to what I attached it would tell you quite clearly you need a 6/21 and no adapter with 4.33's and G-70 14's (25.1" diameter).
Simple as that.
-RONALD REAGAN
Old 08-20-2011, 09:31 PM
bulletpruf's Avatar
Simple as that.
I read your post and downloaded the Excel document - "GM Speedometer Gears." What was clear to me after reading the document is that it did not contain all the information I was looking for. As I stated in my initial post and in a later post, I am looking for "correct" parts - - as in original equipment. In other words, this is a resto project, so I want my speedometer to be accurate, but if my car came with an adapter, I wanted to know that as well. So, I appreciate your input, but your document offered no info on the adapter question. Simple as that.
Old 08-20-2011, 10:42 PM
Held for Ransom's Avatar
Scott, I'm not sure where the 6 grooves comes from on the drive gear ('69 Firebird w/4speed and 4.33:1 was 7). But, here is a copy of the parts manual...
Old 08-21-2011, 08:50 AM
bulletpruf's Avatar
Thanks, HFR.
Scott
Old 08-21-2011, 10:46 PM
marxjunk marxjunk is offline
I dont know if this helps but 70 manifest/option code says
sales code#591 upc code w55 speedometer adapter w/special order gear ratio..so it says it needs one..
I have had a few, i actually have one off a 70 white Ram IV Judge my buddy bought out of a yard in the late 80s, the car was apart like some one took it apart to restore and it never made it back together..inside the car was the flappers, the air cleaner, a set of 4.33 gears and a speedo adapter...i kept the adapter, but cant find it right now....i have several, and they are easy to get if you know where to look...late 60s to early 70 1 ton chevy trucks with 4.10 4.56 and 4.88 gears and the big muncie granny low 4 speed...i get them every time i see them, and sell them quickly to the chevy boys.....anyway, they are identicle in appearence to the one out of the judge...
Old 08-21-2011, 10:48 PM
i've been looking since you posted this and cant find the box they are in...i will look some more..
Old 08-22-2011, 04:56 AM
bulletpruf's Avatar
Appreciate you looking for this. Does it look like the one pictured below?
Thanks,
Scott
Old 08-22-2011, 02:00 PM
yes
Old 12-29-2019, 02:51 PM
bulletpruf's Avatar
Bumping an old thread...
Found one of these in my GTO parts stash. It's stamped .8241 and it looks just like the one My442 posted below.
Looking at the ones on eBay, it appears these were made by Stewart Warner and the going rate is about $50.
I'll be selling this one if anyone needs it.
Scott
