Old 01-12-2020, 06:37 PM
andy andy is offline
Default 65 gto carb mounting gasket question
installing Carter AFB on intake 9778816
Do I use a 1/4 inch felpro 13834?
I bought it used and owner said he took thin gasket out,
but I don't know what style.
mr gasket 55?
ID:	528742   Click image for larger version
ID:	528743   Click image for larger version
Name:	Felpro 13834.jpg
Old 01-12-2020, 09:08 PM
Cardo's Avatar
Cardo Cardo is offline
I always use the 3rd one in mine. Helps a little bit with heat isolation. You may need longer carb studs, or back yours out slightly.
"I know just enough to keep me here, but not enough to get me out"
Old 01-12-2020, 09:55 PM
8LUG 8LUG is offline
Default gasket
#3 real close to original
Name:	intake gasket.jpg
Old 01-13-2020, 08:05 AM
65 421 TODD's Avatar
65 421 TODD 65 421 TODD is offline
8LUGs photo shows the GM gaskets I use. With the GM's the automatic choke heat tubes lined up and fit on the carb correctly. Notice the GM's rivets are slightly "flattened" and "below" the surface thickness of the gasket material so as not to interfere with the gasket material creating a good seal between the carb and the intake manifold. I mention this because years ago I tried an aftermarket gasket and those rivets were "thicker" or "higher" than the gasket material and I had a bad vacuum leak.
Old 01-13-2020, 09:09 AM
thanks for the advice and guidance!
