1968-69 GTO/LEMANS PARTS
1968 Hurst Dual Gate Shifter Restored with shifter cable and wiring harness $525.00
1968 Carb Restored $900.00 1968 Rear bumper brackets $75.00 1968 GTO Passenger door Glass with lower frame and bracket $100.00 1968-69 Lemans front bumper brackets $75.00 1968 Lemans front bumper black plastic insert $25.00 1968 Lemans front bumper grill brackets $25.00 1968-69 power brake booster $50.00 1968-72 GTO/Lemans lower main duct and vents $125.00 1968-72 Intermediate steering shafts $50.00 1968-72 Rear Windshields $80.00 1968-72 Coils $25.00 1964-79 Oil Filter housings $85.00 each 1968-72 front lower window reveal molding $60.00 1968-72 rear front upper fender chrome moldings $30.00 pr. 1968-71 Throttle cable $45.00 1965-78 Turbo 400 Transmission oil pans $50.00 1968-72 NOS FRONT WINDSHIELD UPPER STAINLESS MOLDING $175.00 1968-72 NOS PASSENGER SIDE FRONT WINDSHIELD STAINLESS MOLDING $90.00 1968-72 door vents pr. $20.00 1968-72 positive battery to starter heat shield tube, 1968-72 1/4 window glass chrome trim moldings $30.00 pr. 1968-72 window regulators set of 4 $150.00 1968-72 brake pedal assembly $75.00 1968-72 emergency brake pedal and bracket $50.00 1968-72 rear license plate bracket and holder $35.00, 1968-72 front armrest bases parchment, black $25.00pr, 1968-72 door & 1/4 glass regulators $50.00 1968-72 water thermostat housings $20.00 , 1968-72 door hinges $50.00 1968-72 points distributors $80.00 1968-72 wiper transmission assembly (2) $75.00 1968-72 blower motors $25.00 1968-72 a/c inner boxes $150.00, 1968-72 headliner bows $50.00 set 1969 GTO CARB still in DELCO BOX $850.00 1969 Water pump Date Code is Jan of 69 $50.00 with divider plate 1969-72 AM &FM RADIO PULLED OUT IN 1983 WORKS $475.00 1969-72 AM RADIO WORKS $200.00 1969-75 Harmonic balancer $50.00 11 Bolt Timing Cover $110.00 11 Bolt Timing Cover withy divider plate and pump $150.00 Full length windage trays 80.00 1968-72 Show Quality Front Window Stainless Moldings, Professionally Polished $300.00 NOS A/C Delco PVC $9.00, NOS PULLEY 481040 still in GM BOX $100.00 NOS A/C Delco oil Filters PF 24 $11.00 each 1969-72 Goldenrod/Tan steering wheel crack free $125.00 1969-72 auto shifters $130.00 Fuel escentrics $35.00 1969-72 harmonic balancer off low mileage car $50.00, flexplates $35.00 1969-72 Standard Gauge & Speedometer cluster $65.00 1968-72 radio rear support bracket $25.00 1968-72 Tag light & bracket $15.00 Distributors 1148 Feb13,70, 1253 Jun 26,68, 2007 Nov 28,69, 2189 Apr 24,72, 2513 Nov 15,73 all distributors $80.00 used pulleys 481040XT water pump pulley, 481038YB crank pulley, 480507 crank pulley, 8inch 2 grove water pump pulley, 480509 TCS Switch $75.00 NON A/C HEATER HOSE BRACKET $25.00 Pontiac oil pan $85.00 new points and condensers __________________ Timmy Mallory Email me at temallory@msn.com
Timmy Mallory |
68 carb 7028270 has been sold thanks Gary!
Timmy Mallory |
