Old 08-24-2019, 07:21 AM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
Default First test in my car, went well!
Took the car (65 Lemans) to the track last night for the first time for some testing. Been working on this car for roughly the past 5 years as time/money allowed. It’s my first effort at a dedicated race car. Previously owned a 72 Lemans street car that I managed to 12.5x in a 1/4 mile - fastest I’d ever been.
First pass off the trailer was an easy go at it to make sure it would accelerate, go straight, no vibrations or crazy noises, and slow down. Which was a success! Car did surprisingly well. After foot-braking and launching at somewhere between 1500-2000 rpms and rolling into about 3/4 throttle from there, car went perfectly straight.
Second pass I tried foot braking again and as I brought RPM’s up at the starting line car pushed thru the brakes, but made another good straight pass.
Third go I played with the trans brake for the first time. First two passes the car hooked up and left no problem. This time I brought RPMs up to around 2500 and left on the brake, tires spun like I was still in the water box. Eased back into it, car responded well. That pass required a small amount of steering to keep it straight. 1/8 mile ET of 6.70 @ 110mph iirc.
(On the return as I slowed to pick up the time slip the car stalled (dead battery) and couldn’t get it fired back up so was distracted from the time slip.)
Really excited that the car did so well. Big adjustment going that fast for the first time... I got nervous during the first pass. Plenty of work to do still but that was encouraging!
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 08-24-2019, 07:42 AM
johnta1 johnta1 is online now
Congrats!
Sounds like some great ET's coming.
Old 08-24-2019, 07:43 AM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Congrats Matt, keep tweaking her you’ll get there
Old 08-24-2019, 07:59 AM
mysticmissle's Avatar
congrats Matt, nothing like shaking down a new build.
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 08-24-2019, 08:12 AM
Elarson's Avatar
Elarson Elarson is offline
Terrific!
Eric
Old 08-24-2019, 08:45 AM
firechickenman's Avatar
firechickenman firechickenman is offline
Great job! Once you get things sorted out, you should be well into the 9's 1/4 mile and getting close to 5's in the 1/8!
'68 Firebird
463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69
2022 - 10.13 @ 133.07
9.93 run - https://youtu.be/hII0_UlYM4U
Old 08-24-2019, 09:10 AM
Scott65's Avatar
Scott65 Scott65 is offline
Good job
Old 08-24-2019, 09:25 AM
AIR RAM AIR RAM is offline
Congrats! You are running very well considering the car is new and its the fastest you have ever been... Cant wait till you are more familiar with the set up and you get all the bugs tweaked out... so far the only bugs sound like the battery and suspension (traction on launch)... good luck & have fun!!!
"The grass is not greener on the other side, its just fertilized with different $h!t"
Old 08-24-2019, 11:10 AM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Very, very nice!
Enjoy
Old 08-24-2019, 11:34 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Congratulations....good job!
Go fast, see Elvis!
Old 08-24-2019, 12:14 PM
chiefbigb chiefbigb is offline
There is allot of time there in just making passes. I would not change allot if your plugs look happy and keep making passes. When the slips level out you can find the rest. I'm happy for you.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
Old 08-24-2019, 12:29 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Congratulations! First passes in a brand new racecar=scary! Glad it went mostly well and only minor issues.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 08-24-2019, 02:59 PM
Dragncar Dragncar is offline
Congrats. You have been at this for awhile now. Nothing like seeing the fruits of your labor.
Old 08-24-2019, 04:50 PM
bpenrod bpenrod is offline
Where did you go?
Old 08-24-2019, 06:09 PM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
Hard to have a better day than that !! She's just going to get faster for you as you figure her out. And another nice 65 Pontiac on the track. Congratulations
Old 08-24-2019, 08:41 PM
slowbird's Avatar
slowbird slowbird is offline
Great start, congrats!
Old 08-25-2019, 06:40 AM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Congrats!!!
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046 jet
First ultra street/ultimate street NOS car to get into the 4's!
1.079 4.559 153.23.
3100 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
T2TTFMF!
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 08-25-2019, 09:20 AM
Thanks fellas!
bpenrod, I went to Kentucky Dragway in Clay City. (Previously known as Mountain Park Dragway)
Matt
70 GTO 400 4-speed
Old 08-25-2019, 09:56 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
110 mph in the 1/8 is rolling. It will just get faster once you It on out the combo. Nice job.
Old 08-25-2019, 10:42 AM
Thanks fellas!
Give me a shout next time you go, night time in the hollar is hard to beat.
