Old 11-16-2019, 10:29 PM
1965gp 1965gp is offline
Default 72 build finally getting close to completion
Thought I would share some details on my 72 build.... this is the car as I bought it. $2300 and I drove it home. The plan was to paint it Carousel Red, Formula hood and honeycombs.
Old 11-16-2019, 10:37 PM
After some soul searching I decided to make it a TA clone. I have a soft spot for early second gen TA’s so I decided to paint it red like a 73 (I already have some white and blue cars).
The bodywork started- the only rust was from a vinyl top. The car had been hit from behind so we decided to replace the quarters, tail panel, etc.
ID:	524612   Click image for larger version
ID:	524613   Click image for larger version
ID:	524614   Click image for larger version
Old 11-16-2019, 10:49 PM
As most here probably know a 2bbl carb doesn’t sit in the right spot for a shaker.
I went to my local shop to see if they had a 4bbl intake. They did- attached to a really nice 67 400 with 670 heads that was pulled out of a GTO for a LS conversion.
I bought the motor and my neighbor built a nice turbo 400 for it.
Since the motor was out I decided to clean the frame, then the floors, then it made sense to rebuild the suspension. I don’t know if I have pics- but I went with Pro Touring F Body kit. I bought tubular upper/lowers , subframe connectors, rear leafs, sway bars, pretty much everything they sold.
ID:	524616   Click image for larger version
ID:	524617   Click image for larger version
Old 11-16-2019, 11:01 PM
This is where the project stalls. Work, life, other projects, pretty much anything took priority. I bought the Kore 3 C5 brake kit and a 79 disc rear but I couldn’t get motivated to finish it. I had a friend that needed $$ to finish his 69 so I gave him my car, a bunch of parts and some cash. Unfortunately after about a year there was no progress made. The $$ was gone and the car was still in pieces. There were chips and scratches all over the car.
I finally got fed up and picked up the car and parts. I took it to the shop I usually use locally that I feel like I ca trust.
I knew it was going to cost a lot more to finish it, but at this point I had a lot of shiny expensive parts and nothing to show for it.
Within a couple weeks the local shop had the car running great. A few weeks later the suspension was finished. Then the big brakes, gauges, etc.
Old 11-16-2019, 11:08 PM
Undercarriage pics
ID:	524621   Click image for larger version
ID:	524622   Click image for larger version
Old 11-16-2019, 11:14 PM
This is the car at the shop that got the car running and driving, along with the rest of the Pro Touring F Body braces and vintage air
ID:	524624   Click image for larger version
The Following User Says Thank You to 1965gp For This Useful Post:
Old 11-16-2019, 11:19 PM
Finally we are up to date. The car is back home, the grills are in along with the HID lights. I’m in the process of putting the interior in. I’m going to put sound dampener down then I am just waiting on windows and the seat covers. Hope y’all like the Pics!
Old 11-16-2019, 11:20 PM
Forgot pics!
ID:	524626   Click image for larger version
ID:	524627   Click image for larger version
Old 11-16-2019, 11:26 PM
These are the speedhut gauges the local shop installed. You can order these in any color, font,logo, etc. really happy with this product.
Old 11-16-2019, 11:55 PM
OZZIEVILLE 67 2 door's Avatar
OZZIEVILLE 67 2 door OZZIEVILLE 67 2 door is offline
Great story 1965gp
That car looks brand new
And yes,love the pics
Thanks for sharing
John L.
Sent from my SM-T585 using Tapatalk
Old 11-17-2019, 08:55 AM
77 Canamman's Avatar
Nice quality build. Thanks for sharing.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 11-17-2019, 09:02 AM
T/A addict T/A addict is offline
BadAss! Great job!
Old 11-17-2019, 09:20 AM
Thanks guys- it’s hard to believe and frustrating it’s taken this long but the car is really coming together nicely.
Honestly to do it again I would probably have stuck with the original plan, saved some $$ and had a decent driver. But, this was an experience I hadn’t gone through. I enjoyed the nut and bolt side of it, just not the ‘hot rodding’ side of it. Figuring out what did and did not work, lots of modifications, 1/2 the threaded were metric and 1/2 were standard on the brakes, etc.
Still- it should be a pretty damn nice car once it’s done.
Old 11-17-2019, 10:46 AM
critter's Avatar
critter critter is offline
Those wheels look familiar! Seriously, I like the way it's coming together and those wheels look a lot better on it than my old girl.
12.84 @ 106.89 with street radials.
12.63 @ 108.39 on drag radials.
Old 11-17-2019, 11:23 AM
Yup! The wheels fit great. I still haven’t figured how to put air in them!!!
The car has been out of my possession for so long I forgot about your trick valve stems!
I think the car needs to come down in the back 1/2-1” but I am going to wait until the new suspension settles
Old 11-24-2019, 10:51 PM
I got some work done on the 72 this weekend. I scrubbed down the floors and lined them with sound deadener similar to dynamat. I got the carpet and door sill plates installed as well as the rear arm rests.
Since I had some time left I decided to throw the old seats in and I’m pretty happy with them. They aren’t correct, but they look pretty decent in the car.
I’m second guessing if I need to recover them
ID:	525338   Click image for larger version
ID:	525339   Click image for larger version
Old 12-27-2019, 04:20 PM
This car s getting closer and closer. Got the windows in yesterday. Hoping to get the rear bumper on and the passenger seat in this weekend.
ID:	527554   Click image for larger version
Old 12-28-2019, 12:25 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Looks fantastic and that's a hell of a transformation
Chris D
Old 12-28-2019, 12:57 PM
Gator67's Avatar
Gator67 Gator67 is offline
Very nice! Great color combination.
Old 12-29-2019, 01:19 PM
Thanks guys. It’s been a long project and it’s nice to see it come back together
