Old 11-27-2021, 03:44 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Default Where do your tail pipes exit?
So, I am building the exhaust, My old system exited the car at the rear quarter right behind the tires. My new system is too large to make the turns between the leaf springs (3.5") I will probably have them exiting out the back under the bumper with slight turn downs, not pointing straight out. Or should I just point them straight out the back? Anyone have pics of how you did yours? Pic is of my old system. Its hard to see the tailpipes since they are painted black.
Old 11-27-2021, 04:04 PM
Vid's Avatar
Vid Vid is offline
Old 11-27-2021, 04:41 PM
72projectbird's Avatar
On my 71 I ran them dumped before the axle for a few years. I switched systems and ended up doing what you're thinking about doing, and now they exit right at the bottom of the quarters facing the ground.
These are the only pics that really show the exhaust.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 11-27-2021, 07:59 PM
AG's Avatar
AG AG is offline
If they have a steep angle pointing straight down they will blow up a lot of dust if you are in a dirt parking lot.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 11-27-2021, 08:03 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Scott my Torque Tech 3" on the 78. Same pipes on the Camaro/IA
Name:	78 sode view.jpg
Skip Fix
Old 11-27-2021, 08:49 PM
ta man ta man is offline
Do you need the 3.5 inch tails?
Old 11-27-2021, 09:02 PM
turbo69bird's Avatar
While mine are 69s I have had a couple that exit in front of the axle one 4 inch Would turn out towards the rockers 45 degrees (got lots of fumes in the car)
3 inch ended in front of axle straight back, lots of fumes in the car.
Full 3 inch exhaust goes back over axle then 2.5 to 1/4s I get fumes
Only my 69 w pipes straight out the back and kinda long on either side of my license plate frame didn’t get any fumes in the car
Hope that helps . Nothing I hate more than fumes in the car when I’m driving it my turbo car is very drivable but will make your eyes water after 25 min of driving . Gonna go straight out the back at some point but my coil overs are right where I want to run it.
960 HP @ 11 psi, 9.70 at 146.
Old 11-27-2021, 09:15 PM
This is true. The way they were aimed with the 3" did kick up some dust in some areas.
Old 11-27-2021, 09:19 PM
No, I have built the tailpipes from mandrel bends. I have them about 75% complete. Have both built over the axle and just need to finish running them out the rear. I really would like them to exit at the quarter behind the tire but the 3.5" won't fit between the leaf spring and quarter where it would travel. So its going out the back, maybe with a 45* turn down, maybe straight out with a angle cut at the end
Old 11-27-2021, 09:20 PM
X2
Mine blow chit every which way. Dust, sand, leaves, everything lol
1987 Grand National
Old 11-27-2021, 10:31 PM
Tom Vaught's Avatar
Boost Engineer
I ran mine exactly the same way because people complained in my 64 convertible when they sat in the back seat and the car was running
but parked at the drive-in. They loved the Camshaft noise, hated the fumes.
Tom V.
255/265 @ .050 solid lifter Comp Cams, 106 c/l.
Old 11-27-2021, 11:16 PM
krisr's Avatar
krisr krisr is offline
In the middle with v-bands right behind the axle so removal of everything is pretty simple and gasketless. Trunk mounted cell.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120
'66 Pontiac GTO - 389, 4 speed street cruiser
Old 11-27-2021, 11:51 PM
android 211 android 211 is offline
I've had the dump tubes in front of the rear axle and I think it contributed to nose inside the car. Same mufflers and tailpipes added ('68 Firebird) and the car was a lot quieter inside. My '69 GTO has stock exhaust tailpipes and I like the look of the tip of the pipe poking out under the corner of the bumper. Quiet too.
Old 11-27-2021, 11:52 PM
Slight turndowns out the back..
Sent from my moto g stylus (2021) using Tapatalk
Old 11-28-2021, 08:37 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
if you go to the rear lower 1/4 n like 72"projects ....be sure to also ANGLE them OUT a little bit. IIRC your looking for about 45* verticle and 20* outside. This will help minimize the BOOM BOOM BOOM ..UNDER the car, Also takes out just a midgen of the flowmaster drone..
The Following User Says Thank You to 67Fbird For This Useful Post:
Old 11-28-2021, 10:03 AM
Looking at one of these 2 styles. Obviously neither car is mine I will probably build each style, and see which I like best.
ID:	578705   Click image for larger version
Old 11-28-2021, 10:45 AM
GoGoat GoGoat is offline
I have 2 cars with each style of exit. The straight out back sounds best, keeps my car cleaner, and keeps others happier at events on gravel or grass. Just depends on your circumstance and desires. Good Luck
Old 11-28-2021, 11:50 AM
Formulajones's Avatar
I prefer to have the tailpipes appear as the factory intended, so it's a little different for each car. They may be larger than factory but still mimic the original shape and exit style on that particular car.
As an example, on dad's car he kept the original resonators from the car when he bought it new, so I took the Torque Tech 3" tail pipes and trimmed them to mimic the same shape.
ID:	578732   Click image for larger version
https://youtu.be/XqEydRRRwqE
Old 11-28-2021, 12:06 PM
Chris65LeMans's Avatar
Exit behind the rear tires, pointed down slightly. Can hear the exhaust bouncing off the car next to you.
Old 11-28-2021, 02:28 PM
fairwayhit fairwayhit is offline
I’m going through this right now.
I’m fitting the new exhaust system. It’s a lot more work than I thought it was going to be.
I like the exhaust to tuck up under the car instead of hanging down. I’m positioning the tail pipes to exit in front of the rear valance and turn down.
Sure doesn’t leave much room. I’m trying to make sure I can get at least a finger between the exhaust pipes and the frame/ floor etc.
