Evaporative Canister Carb connection
So I have the stock evaporative emissions canister and all factory lines from the tank/separator to the restricted rad support hardline to the canister. The problem is I do not have a quadrajet any longer. Instead I have an AVS. So the question is, what should I connect the carb port on the canister too? This is the two port canister, tank and carb,.
I have thought about plumbing it into the PCV line with a tee, but it seems like it is not metered and would just be a giant vacuum leak. Any ideas? Thanks,
I built it one piece at a time and it cost me more than a dime. |
A ported vacuum port is all that is needed for your canister.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
If things are not factory correct, forget about it.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8” Flakes F ire B irds 🇮🇱 |
Ported vacuum will work for this as 77 has stated.
Some ran it through a temp switch on intake, but just hooked to ported vacuum is fine. Restricted pipe will keep car from having a vaccum "leak" |
The Following User Says Thank You to Formulabruce For This Useful Post: | ||
Thanks, I am going to connect it to the ported and give it a go.
The Following User Says Thank You to fbody_mike For This Useful Post: | ||
Been running the canister connected to the ported vacuum port and it has been working great. No odor of fuel at all around the canister and I did not notice any change to the engine's response. Thanks for the responses!
