Old 02-28-2021, 01:30 PM
SD455DJ SD455DJ is offline
Originally Posted by Tellyshavilli View Post
Raiv 70TA
Sorry about the pictures being rotated if somebody knows how to correct them feel free
Matt, Is the vent tube hole in a different location than the '71 as well?
Dennis
Old 02-28-2021, 02:04 PM
Hey Craig! Yeah, the '71 wouldn't have the "Holley Bumps"....forgot about those that are '70 only for the stillborn LS1 RAIV that almost happened.
Dennis
Dennis ,I looked at the bumps in the 70 air cleaner and the 71 air cleaner and they’re the same and the hole location is the same ,the only difference is the hole location for the valve cover breather tube which on the 70 is closer to the snorkel by a substantial amount
Old 02-28-2021, 03:41 PM
Thanks Matt for the RAIV TA base pics. That got me wondering about the air cleaner bases for the 70 vs. 71 RA Formulas. It looks like they didn't change the vent tube location between the years, but not sure if the "Holley Bumps" were removed for '71 (no pictures without the lid...so I can't say for certain if they are, or, are not there). I also included '71 A & F body dual snorkel 455HO air cleaner base pictures for comparison...
Dennis
Name:	70 F RAIII Air Clnr 1.jpg
ID:	561767   Click image for larger version
Name:	71 F RA 455HO.jpg
ID:	561768   Click image for larger version
Name:	71 F Dual Snorkel 455HO 2.jpg
ID:	561769   Click image for larger version
Name:	71 A Dual Snorkel 455HO 2.jpg
Old 02-28-2021, 04:00 PM
Dennis
Look at your third picture and see how close the valve cover breather tube is to the snorkel that’s got to be a very early 71 air cleaner or a 1970
Old 02-28-2021, 04:59 PM
Matt, It's an 05B build car from Van Nuys and it has the original '71 455HO dual snorkel air cleaner, but I would image all the 455HO air cleaners were produced early on in the model year and probably over stocked since PMD made only 159 non-RA 455HO Formulas that year...so, not surprising it is patterned off the 1970 unit.
A couple questions:
Did the '71 TA/RA/Dual Snorkel bases have the "Holley Bumps"?
Were the TA shaker bases the same, except for the wing nut tabs welded on?
Dennis
Old 03-01-2021, 12:45 AM
A couple questions:
Dennis
Bumps look same on 70 & 71 air cleaners 70-72 FORM & TA based r same except tabs and functional snorkel
Old 03-01-2021, 07:54 AM
Thanks Matt! So the stripped air cleaner base/tub serves as the core for the different hardware (snorkels, RA Formula intake extensions, TA shaker lid tabs)...makes sense to me.
Dennis
Old 03-01-2021, 08:12 AM
Dennis
I’ll have to double check on the ram air formula air cleaner
Old 03-01-2021, 11:08 AM
So after looking at the 70 ram air formula air cleaner, the bases do look the same obviously the openings are bigger for the formula Heat riser extensions and the location seems to be slightly different
Old 03-01-2021, 01:51 PM
I have to agree with your assessment after looking more closely at the pictures.
Thanks for checking and posting the pics.
Dennis
Old 03-01-2021, 05:45 PM
Dennis,
Here is a picture of the original RA air cleaner off my 71 Formula.
Name:	RA air cleaner.jpg
Old 03-02-2021, 07:43 AM
Originally Posted by eaglesan13 View Post
Dennis,
Thanks Chris! It sure looks like the RA Formula air extensions (not sure what to call them...) openings at the base are wider and a different profile than the TA/Dual snorkel openings.
I'll have to compare them side by side when I'm back over at Dan's.
Dennis
Old 03-02-2021, 07:38 PM
On factory RA air cleaners with studs on the snorkels, how were they originally secured to the brackets, with nuts or wing nuts?
Old 03-02-2021, 07:49 PM
unruhjonny's Avatar
I had understood they used wing nuts - the same kind as the air cleaner lid.
1970 Formula 400
Old 03-02-2021, 11:50 PM
Wing nuts.
Old 03-03-2021, 11:03 AM
RamAirBirds RamAirBirds is offline
Default 1970 T/A ram IV question
O.K., so I have here the original RAIV pan for my 1970 TA...Took some photos of the "plug" that was installed originally...This is what you would find on the 70 TA pan that DOES have the 71 up hole in it...
Ross Anderson
ID:	561955   Click image for larger version
ID:	561956   Click image for larger version
ID:	561957   Click image for larger version
Old 03-04-2021, 09:25 AM
Ross Anderson
That'd be the one....thanks Ross!
Dennis
  #38
Old 03-04-2021, 09:37 AM
I wonder how many wingnuts vibrated off the undersides of the air cleaners back in the day. I'm also sure the nuts and the brackets were discarded often since they are a pain to deal with every time you want to remove the air cleaner and/or valve covers.
Dennis
  #39
Old 03-04-2021, 12:01 PM
4birds's Avatar
4birds 4birds is offline
Dennis, do you know what years and which body styles used the 2 support brackets to the underside of the Ram Air air cleaners?
(In my case 1972 HO Formula and 1972 HO GTO)
Sorry for getting off the OP topic.
  #40
Old 03-04-2021, 12:19 PM
My understanding is '70 & '71...'72's & up didn't have the studs, so no brackets. Possibly early '72's had them as well. Tellyshavilli probably knows for sure.
My apologies to the OP as well for continuing the derailment...
Dennis
