Old 02-15-2021, 12:32 PM
fbody_mike's Avatar
fbody_mike fbody_mike is offline
Default Evaporative Canister Carb connection
So I have the stock evaporative emissions canister and all factory lines from the tank/separator to the restricted rad support hardline to the canister. The problem is I do not have a quadrajet any longer. Instead I have an AVS. So the question is, what should I connect the carb port on the canister too? This is the two port canister, tank and carb,.
I have thought about plumbing it into the PCV line with a tee, but it seems like it is not metered and would just be a giant vacuum leak. Any ideas?
Thanks,
I built it one piece at a time and it cost me more than a dime.
Old 02-15-2021, 12:49 PM
77 Canamman's Avatar
A ported vacuum port is all that is needed for your canister.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 02-15-2021, 05:58 PM
burd's Avatar
burd burd is offline
If things are not factory correct, forget about it.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here
Just Say No To 8” Flakes
F ire B irds
Old 02-15-2021, 08:46 PM
Formulabruce's Avatar
Ported vacuum will work for this as 77 has stated.
Some ran it through a temp switch on intake, but just hooked to ported vacuum is fine. Restricted pipe will keep car from having a vaccum "leak"
The Following User Says Thank You to Formulabruce For This Useful Post:
Old 02-16-2021, 05:16 PM
fbody_mike's Avatar
Thanks, I am going to connect it to the ported and give it a go.
The Following User Says Thank You to fbody_mike For This Useful Post:
Old 03-17-2021, 11:35 AM
fbody_mike's Avatar
Been running the canister connected to the ported vacuum port and it has been working great. No odor of fuel at all around the canister and I did not notice any change to the engine's response. Thanks for the responses!
