1970 Trans am Fan Spacer
Was wondering what would be considered the correct length of fan spacer for non AC application....with 5 blade flex fan?
Parts book shows a 1 7/8"...and 2 1/4". Mine had a 2 1/4" installed and there wasn't much fan coming out of the shroud. Found a 2" on the shelf....and may give it a try.... Also were any washers used between bolt head and fan? (I think not) |
Have you looked at the 1970 Assembly Manual? P84.
The 5-blade flex fan seems to call for the #3927793 spacer. Google says that's a 2.25" fella. No washers. https://www.musclecarcentral.com/196...-p/rad-754.htm |
I was hoping somebody here might have a 70 TA....and tell me what size is on their car.. |
No, you said you came up with two and I didn't quote the Parts Manual which is often wrong. I simply provided an extra confirmation that you may not have seen, or else you wouldn't have asked about washers either. Don't worry, it won't happen again.
You seem to be an "expert" on these cars...... Have you ever owned...or worked on a 70-73 Trans am....or are we just good at googling? Last edited by Green Hornet; 02-16-2021 at 10:27 AM. |
I'll measure mine and get back to you.
2.250 is correct
No one said I'm an expert, I sure didn't. Unless that is someone who goes out of their way to look up info or try to find pics when someone requests something. I do that a fair bit. My apologies for giving you the correct answer and extra information you requested but did not have. That must really suck. No googling, I had to pay for these manuals like many others.
The Following 2 Users Say Thank You to Aus78Formula For This Useful Post: | ||
